Ricoh MP6001 dead from firmware upgrade
  • kannuki2
    • Feb 2012
    • 398
    Happy new year guys, ran into a problem where I was in the middle of a firmware upgrade on the machine and power went down (dead). After got power, the "Please wait message" will not clear.. are there any way to revive the machine without breaking a limb or two?
  • anothertech
    • 1771
    Re: Ricoh MP6001 dead from firmware upgrade
    Try this , press 143, then clear stop key 3 times, then reboot.
    • kannuki2
      • Feb 2012
      • 398
      I did 143 too and no luck. What parts would need to be replace in order to fix this problem?
      • anothertech
        • 1771
        Have you tried anything with the harddrive? Try a new harddrive or remove the old one and format it with your laptop.
        • kannuki2
          • Feb 2012
          • 398
          Yup, I replaced controller and hdd with no luck..
          • RG1964
            • Jul 2009
            • 56
            When the power went down, it might have been updating de control panel.
            The only solution is to replace this panel because you can't replace the nvram that's blocked.
            The manual will tell you that the update will continue. BAD LUCK
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Check the manual, there was a procedure to boot from the sd card with dip sw settings on some older models, and some also had a boot sd card you could get to recover.
              Mystic Crystal Revelations
              • Oze
                Ricoh Fanboy
                • Jul 2008
                • 1663
                But tbh you'd have to be the unluckiest bugger since Bin Laden's hideout coordinator......power going out mid firmware upgrade.
                • tcs04
                  FORMER Techie
                  • 1183
                  Dip sw 1 on???
                  • kannuki2
                    • Feb 2012
                    • 398
                    Hahha.. funny.. Yea i guess I am one of them.. it was storming that day and the tree fell down on one of the electrical wire. Anyways, I just want to thank everyone on this, the BCU and nvram resolved the issue.
                    Don't do firmware updates on a rainy day... beware.................. beware...........haha
                    • akewldewd
                      • Dec 2012
                      • 83
                      Just curious, what exactly fixed this issue?
                      • mrwho
                        Major Asshole!
                        • 4299
                        I believe he said it was the BCU and NVRam...
                        Mascan42
                        Ibid
