Happy new year guys, ran into a problem where I was in the middle of a firmware upgrade on the machine and power went down (dead). After got power, the "Please wait message" will not clear.. are there any way to revive the machine without breaking a limb or two?
Ricoh MP6001 dead from firmware upgrade
Re: Ricoh MP6001 dead from firmware upgrade
Try this , press 143, then clear stop key 3 times, then reboot. -
Have you tried anything with the harddrive? Try a new harddrive or remove the old one and format it with your laptop.Comment
When the power went down, it might have been updating de control panel.
The only solution is to replace this panel because you can't replace the nvram that's blocked.
The manual will tell you that the update will continue. BAD LUCK
Check the manual, there was a procedure to boot from the sd card with dip sw settings on some older models, and some also had a boot sd card you could get to recover.Mystic Crystal RevelationsComment
Hahha.. funny.. Yea i guess I am one of them.. it was storming that day and the tree fell down on one of the electrical wire. Anyways, I just want to thank everyone on this, the BCU and nvram resolved the issue.
Don't do firmware updates on a rainy day... beware.................. beware...........haha
Just curious, what exactly fixed this issue?Hahha.. funny.. Yea i guess I am one of them.. it was storming that day and the tree fell down on one of the electrical wire. Anyways, I just want to thank everyone on this, the BCU and nvram resolved the issue.
Mascan42
Ibid
I'm just an ex-tech lurking around and spreading disinformation!Comment
