Gestetner Light Copies
  • copierlady
    • 338
    I Am Working On A Gestetner 3222 (richo 220) It Was Dumping Toner And Had Pcq When I Started We Replace Dum Unit,transfur Unit And Roller, Cleaned Mirrors,rebuilt Fuser Unit,and Put New Toner In Machine. Better Cq, But Still White Streaks From Lead To Trail, And Sky Shot Shows "roller Ridges" In The Light Areas?
    I Should Have Put Richo For My Least Fav Copier!!! Can Any One Help?
  • Jomama46
    • 2900
    Somethings out of whack! Did you use an OEM PCU, if not then process control may not have been performed automatically.
    Look at SP2220. Specifically VT, Vsg and Vsp. Are they normal?
    Look at SP2001 Charge Bias- set to default
    Look at SP2201 Developer bias- set to default
    Look at S{2301 Transfer bias- set to default.
    sigpic
    A+; Network +; PDI+
    • nmfaxman
      • 1702
      clean the laser slit glass. If it was dumping toner it got on the laser unit.
      • Jomama46
        • 2900
        Nice catch, NM
        sigpic
        A+; Network +; PDI+
        • npwright
          service manager
          • 12
          re pcq on 220
          clean laser slit glass and possibly if toner dumping was severe you may have to open laser unit and clean all mirrors,
          also check that both springs are in place on the charge roller and that one hasnt dropped off, also worth checking that dev unit hasnt got an obstruction in it stopping dev getting to the cylinder.
          • copierlady
            • 338
            Thanks When I Cleaned The Laser Slit Glass I Got Beautful Copies I Didn't Have To Go Any Deeper Thank Goodness. Thanks Again- Copierlady
              • 22999
              Good catch faxman! When it dumps, its right onto the slit glass.
              • Jomama46
                • 2900
                Thanks Ricoh, for the guaranteed service call.
                sigpic
                A+; Network +; PDI+
