web cleaning with my ricoh mp 5500
  • Exok
    • Jun 2011
    • 750
    #16
    Re: web cleaning with my ricoh mp 5500
    If the web is getting wrapped around the press roller, there is a pretty good chance the web gears have become stripped.
    • Codex
      • May 2008
      • 701
      #17
      i have the same problem with many Aficio 2075...changed the fuser web, and after a while SC 550 comes up......set SP 1902 to another value, (+ - 10) and it works for a while, and then again SC 550....
      i have a tool to check the web motor, some batteries with a conector that fits the web motor, so i can see if everything works fine.
      Memento Audere Semper
        • 37483
        #18
        Originally posted by jam-o-matic
        Re-check the web drive motor harness, i've had a few where the tech pinches the wires. Verify the web is turning by making a mark on the web and turning on the web motor, it barely moves, so sometimes i pull the motor off the frame, cheat the door closed, and drive the web motor thru the Output check. I think this model has 2 spots to reset the web when you replace it in SP mode & PM counter. Good luck!
        I had one machine where the harness was rubbing against the head of a screw and shorting to ground every two to three days. Moved the harness to where it didn't touch the screw.
