MPC2500 LINES
  • mikadonovan
    • May 2008
    • 2931
    MPC2500 LINES
    Hi, All. I have a Savin c2525(b230) with lines at the bottom of everything, prints,copies, and internal data prints. I initially thought it was a charge roller line on black pcu, but not so. The line even occurs on ALL colors of the internal test page prints. All PM parts are well within there expected lifespan. I did replace the K pcu, itb cleaning unit, k pcu and fuser, no joy. ITB belt is in excellent condition. I'm leaning towards a problem with the LD unit. Has anyone ran into this problem before?
    The line are light, and you can only see them a little on the bottom of the red area, although they actually are occurring across the entire page every inch or so, and they are about 2 inches high. I scanned them at hi res, and they still didn't show up well.
    NEVER ASSUME ANYTHING
  • HP:guy
    • Feb 2013
    • 279
    Re: MPC2500 LINES
    Did you look @ the transfer cleaning area?
    • andy227
      • Jan 2013
      • 219
      Re: MPC2500 LINES
      I see the lines on your sample. I don't think its a LD problem, doubt it very much. It looks like a defect on one of the charge rollers, especially if its every inch or so, OR possibly on one of the developer mag rollers. Its not an issue if the units are still within their lifespan, Things can still go, and they do on these, bad well before the lifespan. Depends on how the customer's been using the machine. Have a close look at the charge rollers and magnetic rollers.
      Nooo.... there would be streaks, or repeated print, not those lines.
      • rthonpm
        • Aug 2007
        • 2859
        Re: MPC2500 LINES
        Try doing sky shots in single colour mode. You may have to enable it from SP Mode to do it, but it should help you narrow down which PCU to look at.
        • mikadonovan
          • May 2008
          • 2931
          Re: MPC2500 LINES
          That's why I used SP 2109-005 for test patterns. By selecting cyan, yellow or magenta individually I should be able to pinpoint which pcu is at fault. I have used this many times in the past to isolate the offending pcu/dev unit. The lines are on ALL individual colors. If it was a particular pcu/dev unit problem it should only appear on the color that has the fault, not all of them. Am I wrong in this logic?
          • andy227
            • Jan 2013
            • 219
            Re: MPC2500 LINES
            Technically yes, but If my memory serves me right, I had a blip on the black drum that would also appear on the individual colours. I think to be sure, if you have another used or new charge roller, substitute it in each unit and see if the fault goes away. the charge rollers unclip out easy enough without having to dismantle the pcu. Should be able to tell in a few minutes if a charge roller is at fault. Thats what I would do anyway.
            • mikadonovan
              • May 2008
              • 2931
              Re: MPC2500 LINES
              Turned out to be the K development unit, which is one thing I did not have till this morning. Took way too long on this repair. It happens occasionally.
              • andy227
                • Jan 2013
                • 219
                Re: MPC2500 LINES
                so it was a mark/scratch on the black mag roller ?
                • mikadonovan
                  • May 2008
                  • 2931
                  Re: MPC2500 LINES
                  After a thorough cleaning of the dev unit, the only thing I found was the front side mag roller seal was folded over. The unit is now in another machine and functioning normally.
