ricoh mpc4500 refuses to duplex....
  • AlcanMan
    • Jun 2025
    machine jams anytime you try to run a duplex job. Print on first side only, page jammed on diverter on way into fuser for second pass. installed inverter assy. problem still present. any suggestions greatly appreciated in advance!
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh mpc4500 refuses to duplex....
    Have you performed an INPUT check?
    • sandmanmac
      • 3979
      What jam code (s) is it logging?
      • nmfaxman
        • 1702
        1 way bearings in duplex slipping.
        Causes timing problems.
        I just pull them off, clean them and rough up the shaft with a scotchbrite.
        • victor25
          • 51
          On the bottom of the fuser is a black metal guide. Remove the 2 screws, clean the metal guide, and when you put put it back on use the square holes instead of the round ones. This allows you to pull the guide back a little farther and make the opening bigger. The paper curls on the second side and catch's it.
          • Tonerbomb
            AutoMajical Resolutionist
            • Feb 2005
            • 2589
            sandmanmac is right on ...what are the jam codes?????
            Mystic Crystal Revelations
            • kannuki2
              • Feb 2012
              • 398
              Check the duplex guide plate for warping? This is known on this model when it has 500k and up
              • Counsel
                • Aug 2011
                • 530
                i think i had one like this a while back if i remember right the page makes it about an inch or so into the right side door before jamming, i believe i pulled off the cover on the right side of the door and found the timing belts loose and one ways slipping, i usually take off the one ways and spin a q-tip with alcohol around inside them, clean the shafts, and then make sure the belt tension is good.
                • AlcanMan
                  Machine is logging ( j064) error
                  • sandmanmac
                    • 3979
                    JAM CODE 064 Junction gate sensor does not turn off - check for obstructions in paper path
                    JAM CODE 064 Junction gate sensor does not turn off - check gate motor with SP 5-804-133 & 134 (CW/CCW)
                    JAM CODE 064 Junction gate sensor does not turn off - check with SP 5-803-68, clean or replace sensor as needed
                    • nmfaxman
                      • 1702
                      I have seen cheap/ recycled paper cause this code.
                      Too much curl entering duplex and tagging on the guide plate.
                      $5.00 a case more is not going to break their budget.
