machine jams anytime you try to run a duplex job. Print on first side only, page jammed on diverter on way into fuser for second pass. installed inverter assy. problem still present. any suggestions greatly appreciated in advance!
ricoh mpc4500 refuses to duplex....
Tags: None
Re: ricoh mpc4500 refuses to duplex....
1 way bearings in duplex slipping.
Causes timing problems.
I just pull them off, clean them and rough up the shaft with a scotchbrite.Why do they call it common sense?
If it were common, wouldn't everyone have it?Comment
On the bottom of the fuser is a black metal guide. Remove the 2 screws, clean the metal guide, and when you put put it back on use the square holes instead of the round ones. This allows you to pull the guide back a little farther and make the opening bigger. The paper curls on the second side and catch's it.Comment
i think i had one like this a while back if i remember right the page makes it about an inch or so into the right side door before jamming, i believe i pulled off the cover on the right side of the door and found the timing belts loose and one ways slipping, i usually take off the one ways and spin a q-tip with alcohol around inside them, clean the shafts, and then make sure the belt tension is good.Comment
AlcanMan
Machine is logging ( j064) errorComment
JAM CODE 064 Junction gate sensor does not turn off - check for obstructions in paper path JAM CODE 064 Junction gate sensor does not turn off - check gate motor with SP 5-804-133 & 134 (CW/CCW) JAM CODE 064 Junction gate sensor does not turn off - check with SP 5-803-68, clean or replace sensor as needed Comment
I have seen cheap/ recycled paper cause this code.
Too much curl entering duplex and tagging on the guide plate.
$5.00 a case more is not going to break their budget.Why do they call it common sense?
