Mpc3500 printing gibberish
  • mrfuser
    • 1617
    Client says machine prints gibberish randomly. I have seen prints and indeed it is not correct. Although I can't duplicate it while I am there, of course.
    any ideas?
    kelly
  • mikadonovan
    • May 2008
    • 2931
    Re: Mpc3500 printing gibberish
    Try another driver, and update the firmware. If you're having issues with windows 8, welcome to the club. That OS sucks.
    NEVER ASSUME ANYTHING
    • pbbsinc
      • Nov 2005
      • 92
      Driver issue. Reload, preferably with a different version. Could be firmware or memory isue, but its usually a driver issue (or an old printer installed with same IP)
      • sandmanmac
        • 3981
        So i guess you havent tried anything yourself to correct it?
        Had a 3260 doing the same thing recently and doing memory clear on network and printer functions solved it
        • rthonpm
          • Aug 2007
          • 2854
          A couple of things to check:
          1. Is it always the same application or file that's causing the issue?
          2. Is the copier shared on a server or peer to peer (installed on individual computers)?
          3. Is the machine capable of PostScript?
          • mrfuser
            • 1617
            Different applications. Yes it has the ps chip. Tried different drivers. If I clear memory do I wipe out anything that will make me reload firmware?
            no windows 8, windows 7 this far. No Mac also.
            thanks
            kelly
            • fbriggs
              • Feb 2011
              • 22
              I have seen this when the print driver needs to be re-installed. Of course, make sure the firmware is current. I have also seen where we had to re-install the older version firmware due to incompatibility issues.
              • anothertech
                • 1769
                If all else fails, change the IP address of the copier, then remove and reinstall the print drivers pointed to the new address.
                • zames77
                  Tweak it till it breaks!
                  • 121
                  Have had similar issue on older drivers when printing from browser. If the URL was quite long, the header became corrupted resulting in gibberish.
                  • rthonpm
                    • Aug 2007
                    • 2854
                    If the machine is shared on a server, check whether the same software versions of any applications that cause problems are installed on the server. I've seen times where older versions of Office installed on a server have caused issues thanks fonts or formatting that the server can't read from newer client installed versions. For example: the server may have Office 2007 installed, but users have Office 2010 installed: when sending jobs the newer fonts get turned into gibberish since they're not in the server's font table.
