Ricoh MP CW2200SP close front cover problem
  • zoran.riko
    • 54
    HI, On a NEW MP CW2200SP after 4-6 prints after instalation, the mashine give me an paper jam and after removing paper still stays CLOSE FRONT DOOR. I chek the left and right switches with instrument and they working fine. In INPUT chek shows the left ( double ) switch is open. I chek also the wires from the switches to the board, they are fine too.
    Any suggestions PLS?
  • Comatose
    • Jul 2010
    • 70
    Re: Ricoh MP CW2200SP close front cover problem
    Sounds like a faulty switch if input is showing them open. Try removing switch and use a paperclip to close the circuit on the connector to test if it is the switch or not.
    • zoran.riko
      • 54
      TNX for trying to help me. I replace the switch-es, chek the cabless ( harness ) with instrument, then short-wire directly to the pins of the board and still the same sympthoms: Close Front Cover. Any new suggestions PLS?
      • TonerMunkeh
        Professional Moron
        • 3865
        Next step would be to check the service manual for blown fuse conditions, maybe a fuse on the PSU has popped. Were any options added at PDI, i.e. another roll drawer? Could there be a pinched harness somewhere?
        Hit it.
        • Exok
          • Jun 2011
          • 750
          If your switch is good, harness is good. Replace the board that the switch connects to.
          • dpoutz
            • May 2011
            • 78
            Sorry cant help you out. But have you ever had a 672-01? and I cant get into sp mode/ Thx
              • 37529
              If this started happening immediately after installing, you may have a board defect that should be replaced by Ricoh under new machine warranty.
              • Iowatech
                Not a service manager
                • 3930
                I'm kind of curious if the actuator for the interlock is OK.
                It probably is I guess.
                • Cipher
                  It's not easy being green
                  • May 2006
                  • 1309
                  Pray it has nothing to do with RTB30.
                  • copier tech
                    • 8169
                    Is this is a brand new machine can you swap it out DOA with Ricoh or your supplier?
                    • Moza
                      • 232
                      see my last post on this http://www.copytechnet.com/forums/ri...ighlight=w2200
                      Basically its due to the print head leaking ink (usually black) and shorting out the MCU board. You have to replace both otherwise if you just fit the MCU it will blow again after 30 seconds.
                      • rexrotary
                        • Feb 2015
                        • 19
                        Re: Ricoh MP CW2200SP image quality problem
                        hi,I have facing problem with image quality black thick lines appearing. I have replaced black print head still thick lines on the print, any body face same problem Please revert back to me.
                          • 37529
                          Start a separate thread and you might get some help.
                          • rexrotary
                            • Feb 2015
                            • 19
                            Hi,
                            Please tell me how can i make separate thread
                              • 37529
                              Hi,
                              Open the forum you want to post in. At the top left is a button that says "+ Post New Thread"
