Fiery E-5000 on Ricoh MP C4500 --Lockup--
  • POA_Shaun
    [Dead] Fiery E-5000 on Ricoh MP C4500 --Lockup--
    Any help would be appreciated,
    I have a Ricoh MP C4500 with a E-5000 fiery. It has a history of locking up (00 on Fiery LED display) and having to be rebooted. Wednesday 5/22/13 I reinstalled the 1.01 System SW and the patches in order per the attached Ricoh Doc.
    Now it runs for around 10-15 minutes and locks up with a FF on the display.
    I noted the installation procedure had not been followed as the second DIMM on the MFP board was still in place and the Service Mode Switch For the machines internal NIC (SP 5-985-001) was still set to 1 (Enabled). When I set it per the install instructions to 0 I get a SC650-11 code.
    If I try to remove the Fiery I cannot print to the internal controller and they cannot run it with the Fiery for more than 15 Minutes.
    Ricoh says replace the Fiery MPCB, but I would rather pull the fiery and run it from the internal nic. However as mentioned above, we have not been successful in removing it and resetting back to the built in controller.
    Any ideas?
    Thanks,
    Shaun DesJardins
  • POA_Shaun
    Re: Fiery E-5000 on Ricoh MP C4500 --Lockup--
    Sorry, I could not attach the Patch list documentation so here is the patch order:
    Recommended Load Order:
    01 1-R3DOV Refer to TSB# G878 - 005
    02 1-QWOVA Refer to TSB# G878 - 003
    03 1-UWFVR Refer to TSB# G878 - 007
    04 1-UCLZQ Refer to TSB# G878 - 008
    05 1-T3RFE Refer to TSB# G878 - 009
    06 1-RQQXE Refer to TSB# G878 - 010
    07 1-RWEVP Refer to TSB# G878 - 011
    08 1-T6D9M Refer to TSB# G878 - 012
    09 1-TWN66 Refer to TSB# G878 - 013
    10 1-RYZ7X Refer to TSB# G878 - 014
    11 1-S38XT Refer to TSB# G878 - 015
    12 1-S3C7H Refer to TSB# G878 - 016
    13 1-RH3GA Refer to TSB# G878 - 004
    14 1-XER9Q Refer to TSB# G878 - 020
    15 1-XAUJ3 Refer to TSB# G878 - 017
    16 1-VXUKA Refer to TSB# G878 - 021
    17 1-STKXK Refer to TSB# G878 - 022
    18 1-Z3AU4 Refer to TSB# G878 - 019
    19 1-107AV6 Refer to TSB# G878 - 018
    They all loaded successfully.
    Shaun DesJardins
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Any ideas?
      Thanks,
      Shaun DesJardins
      You can't have the Fiery and the internal print scan option installed on the same machine. The E-5000 is a POS anyway just like the rest of the embeded by a tail "E" Fiery's that are Linux based. Do your customer and yourself a favor, use the internal print scan option.
      Mystic Crystal Revelations
      • Tonerbomb
        • Feb 2005
        • 2589
        Shaun DesJardins
        I think you maybe short a patch or 2. last time I loaded 1 i think there were 21 patches. And with 21 or so patches why doesn't Fiery and ricoh release a new version of the OS that includes all the patches?????????????
        • POA_Shaun
          Originally posted by Tonerbomb
          You can't have the Fiery and the internal print scan option installed on the same machine. The E-5000 is a POS anyway just like the rest of the embedded by a tail "E" Fiery's that are Linux based. Do your customer and yourself a favor, use the internal print scan option.
          I could not agree more. The issue is we cannot get the machine to print once the Fiery has been removed. I have reset the second DIMM (Removed at Fiery Install) and the interface PCB. But even though we can ping the internal NIC, we cannot get it to print or log into the internal web page.
          Any suggestions?
          Shaun DesJardins
          • POA_Shaun
            Tonerbomb,
            I did not see instructions to remove an internal Print / Scan option (I am not familiar with this series), could this option have been either removed, or never installed? This might explain why I cannot get it to print after pulling the E-5000.
            If so, ho would i re-install it? Any ideas there?
            Shaun DesJardins
            • Tonerbomb
              • Feb 2005
              • 2589
              Do you have the print scan SD card installed?? this is key to the internal print option.
              • sandmanmac
                • 3985
                Tonerbomb,
                Shaun DesJardins
                I believe the fiery is an "either/or" type of situation. When it's installed, the usual internal Print/scan kit is not. So I would suspect that there is (at minimum) no Print/scan SD card installed on the copier itself to allow for on board functionality.
                EDIT...tonerbomb beat me to it!..
                • POA_Shaun
                  Thanks guys!
                  We will look into getting an SD card for this and loose the Fiery!
                  Thanks for the help!
                  Shaun
                  • sandmanmac
                    • 3985
                    Thanks guys!
                    Shaun
                    Here's the kit. You may need the Dimm card as well (??)
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      You also need to install additional memory to get the internal print controller to work. If the machine was originally ordered with the Fiery, it will not be there.
                      I've been through this exact exercise - no fun.
                      • milos
