MP 2510 message load A5 size paper
  • nashua
    • Sep 2009
    • 25
    Hi
    one of my MP 2510 once we feed paper in LEF from DF and paper in tray one or two in
    same LEF while copying message in display showing load A5 paper in tray and copying
    in A5 size. Already paper in tray in LEF A4 size is there.
    kindly reply with your expert solution.
    thanks
  • gasior78
    • 29
    Re: MP 2510 message load A5 size paper
    Hi there
    Most probably there's a problem with original width detection in document feeder. Go into SP mode >> 6-016 (ADF Original Size Detection) and check what happens when you slightly bend the ADF's original table. If the values change unscrew original table and improve contact between size detection board and its sliding copper-made electrode. All the best
    • sandmanmac
      • 3979
      Originally posted by nashua
      Hi
      thanks
      Usually it's just the sensors on the DF feed tray that become coated in dust since they face upward, and the DF senses that there is paper. Wipe/blow them off and it should be fine
      • gasior78
        • 29
        Really this is not going to help in case of A5 paper size..
        Those sensors - if activated - detect A4 SEF and larger sizes i.e. A3. A5 will never cover/activate them. Regards
        • sandmanmac
          • 3979
          Maybe or maybe not. Metric paper sizes make my head swell up.
          The nice thing is that it will only take 3.7 seconds to find out if I'm wrong.
          • Iowatech
            Not a service manager
            • 3930
            Does the machine display A5 paper in the appropriate paper drawers? If not, there is a sensor behind the drawers that sometimes gets knocked out of position that will cause the machine to incorrectly detect paper size.
