Ricoh MPC4500 light cyan spots on document
  • tibbs
    • Aug 2008
    • 225
    Can anyone help me with a ricoh MPC4500? it's dropping light blue spots on the documents, i cant seem to find the cause of this problem.
    Thanks any help will be much appreciated
  • sandmanmac
    • 3979
    Re: Ricoh MPC4500 light cyan spots on document
    So you're saying that you've checked the Drum, Dev, and transfer cleaning units (for starters), and they aren't the cause?
    • knightfall
      • Jul 2006
      • 633
      you need to provide more info like what you checked, replaced/switched and your observations and post a sample would help.
      Get your facts first, and then you can distort them as much as you please.
      • mrfuser
        • 1617
        I agree with all above, but most likely either dv or your charge roller on the drum unit is dirty. I clean them all the time and they work fine again, just plain water.
        Kelly
        • knightfall
          • Jul 2006
          • 633
          I guess after a week it wasn't that big of a problem though I wish they would update the post. must be an end user.
