ricoh aficio 3235c color registration
  • copiers89
    • Aug 2025
    [CQ] ricoh aficio 3235c color registration
    20130617100355278.pdf this is the sample any help to adjust reg color the mach couldnt automatic
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: ricoh aficio 3235c color registration
    Please read the user manual:
    http://support.ricoh.com/bb_v1oi/pub...0/B1807540.pdf (page 134, actual page 146)
    • johnyb
      • Feb 2011
      • 167
      If you are a Engineer...To start with....
      • Clean ID sensors.
      • Clean the silver roller on the transfer facing the ID's.
      • Attempt colour reg adjustment.
      • New belt required.
      • Weak colour on a dev unit.
      • The list goes on!
      If you are a customer phone an Engineer.
      PS
      Can be a nightmare when you get this fault on these machines.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • logrady2331
          • Feb 2011
          • 301
          As stated, this problem can be a nightmare - mostly from a cost perspective. If the machine will not do an automatic registration adjustment you will need to follow the service manual and do the "raw" adjustments IN ORDER. You will need a loop. If you don't have one you are wasting your time trying to bring the laser in to rough adjustment. You could have bad developing units, drum inuits, t-belt assembly, the list goes on and on. This problem will really test your knowledge of the copy process. I have seen everyting from bad LSU to dirty ID sensors/transfer rollers all the way to a bad NV RAM. Make sure you have good dev. and drum units, clean ID sensors, good t-belt, etc. IF all that is good do an NV RAM clear and reload the bible settings. If it still fails, make it a parts machine and buy one from any of the wholesalers as they sell these models for around five hundred dollars.
          • bat
            • Sep 2008
            • 140
            Had a same problem on Aficio 3260c, this problem can be a nightmare, I replaced all boards, all motors, PCUs, connectors, everything except Laser Unit. After few months of work I replaced a ITB connectors on chassis, machine is working for two weeks now without color shift, so this might be a solution to this problem... good luck
