ricoh mpc 4500 and fr790 finisher
  • harryecs
    the Ricoh mpc 4500 is networked to 4 computers. One computer works fine with the copier, but the other three show the accessories options as blank. They cannot choose sort or staple options that come along with the finisher. Is this a software problem? Anyone got any ideas? thanks
    • 22999
    Re: ricoh mpc 4500 and fr790 finisher
    Welcome to Copytechnet.
    If you'd like the Ricoh people to see your thread you should start a thread under the Ricoh Forum. That's where they'll look.
    • DWise
      • 895
      Welcome to CTN!
      Do for one what you wished you could do for everyone. - Andy Stanley
      • knightfall
        • Jul 2006
        • 633
        welcome
        Get your facts first, and then you can distort them as much as you please.
        • HenryT2
          • 962
          Welcome !!!
          "The Serenity Prayer" . . .
          God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
          • dgutierrez
            Go to the driver properties, select accessories tab and select the finisher which is installed. Hope this helps
            • Fortion
              • 11
              check the driver version....and google of update version if there is any buy it from manual guy on this forum...
              • UCPrint
                • Oct 2012
                • 24
                That is a wrong driver they are running, or alternativly the driver hasnt been configured properly.
                  • 37362
                  I have also seen this problem when one computer has the driver installed locally and the others are connecting through a server. If the finisher is not selected in the driver on the server, none of the workstations can select it.
                  • rjfellizar2468
                    If you have the correct driver go to Printers - MPC4500(PCL/RCPS) - Driver Properties - Accessories just choose the correct finisher the test. FYI finisher model is SR790. I hope this wil help.
