mp3350 light copies good prints?
  • digicor
    • Jul 2008
    • 1152
    Hey ive got a 3350 with great prints and bad copies, laser lens,scanner glass, mirrors all have been cleaned.
    should i run an image dens adj? but the prints are good so this wouldn't effect it.?
    drum, erase lamps, dv must be good to get a good print right?
    could it be the scanner lamp? or the scanner control board?
    any suggestions?
  • vstar
    • Aug 2007
    • 176
    Re: mp3350 light copies good prints?
    any suggestions?
    What is the PM count?
    On most Ricoh machines a PM will fix this. I think they use differnet charge voltage for copy and print.
    It has always worked for me.
    Cameron
    • digicor
      • Jul 2008
      • 1152
      Thanks ill check.
      • nmfaxman
        • 1702
        Cameron
        X2.
        Fresh drum and DV has solved this for me.
        • Eric1968
          • 2458
          Like Cameron said, do a rebuild of the PCU. I know it sounds strange, but rebuilding the PCU solves it. When I first encountered this I also looked at the optics, but a Ricoh tech told me to do a PCU rebuild. After rebuilding the copy was ok.
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
            Paul@justmanuals.com
            • digicor
              • Jul 2008
              • 1152
              sounds good
              • zsoltee0001
                • Jul 2009
                • 39
                any suggestions?
                is Printing quality good, but scanning is bad?
                Attach a sccnnnig image.
                Print a non-default list from sp print mode, and attach it.
                • Gary Bowen
                  Bowdog
                  • Mar 2008
                  • 250
                  Has this been resolved? I have 2 MP 2851's that have exhibited the same problem - good print quality but lighter copies. I changed SP4460-002 (Digital AE Setting) from a default of 972 to 800 to improve the copy darkness (if you do go much lower than 800 you will get background on printed copies of images scanned to email/folder, so you will need to test a print from scan to email/folder).
                  One of the customers called back and I did an Engine Memory Clear (SP 5810-002) only. I reinput non-default settings except for those in SP 4XXX that cover print vector, black level etc. and this noticeably improved the copy quality; however the MP 2851 can scan in colour so I don't know how that looks (most times it is defaulted to B&W scanning).
                  I have contacted Ricoh Tech Support in regards to this. They thought it might be the IPU PCB which is an expensive PCB in the dealership world. The PCU and Developer were not even at 30K so this would hardly seem to be a factor, and the optics are spotless.
                  • techsass
                    • Dec 2010
                    • 248
                    Try Sp4918 Man Gamma Adj. Bump up the ID Max to 20 +/- on each page/screen. I never bothered with the highlight, etc.
                    You can find it in the manual under Replace & Adj/ Image Adj/ Printer Gamma Correction.
                    I had to do this A LOT on the 3260s for exactly the same reason. I don't work on the 3350, but hopefully it's still there.
                    • Herostrat
                      • Oct 2012
                      • 220
                      I had this on MP3045,I even tryed another scanner and the same,new drum and developer solved it.
                      Gears,springs,clutches,sliders,connectors and electronics...who on earth can tell what's wrong with it?
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Having the same problem here. As far as i can read, there is no solution offered here in this bulletin. Is sp4918 a solution? I very much doubt it! So, the question remains: how can we solve this problem?
                        • sandmanmac
                          • 3964
                          Just wondering...SO you've tried nothing so far?
                          As stated a few times by others early in this thread. PCU replacement has always resolved this for me too
                          • mikadonovan
                            • May 2008
                            • 2931
                            Originally posted by Eric1968
                            rebuilding the PCU solves it..
                            What more do you want?
                            NEVER ASSUME ANYTHING
                            • Mark Bbb
                              • Jun 2012
                              • 1662
                              Wright, but when after a 45K the copies are faint, are you going to replacing the pcu then?
                              A pcu can last at least 70K!
                              So, i'm searching for another solution.
                              But... there isn't one, i understand now...
                              Thanks for replying, anyway!
