Ricoh Aficio 350 ADF sponge rollers inside the belt falling apart
  • patterson70
    • May 2010
    • 599
    Could anyone tell me where I could find the sponge rollers that are glued to the four shafts inside the doc feeder belt? (You have to look inside the area the belt encloses by pulling it back a little) The originals are stopping on the glass sometimes and other times just into the right side duplex area. I see that the foam has disintegrated and I guess that is causing less pressure against the belt. Trouble is they are glued on so it will be a mess replacing them, or maybe replace the four shafts with new sponge rollers alredy installed? Has anyone seen this much, I know the machine is old.
  • Gift
    • Mar 2011
    • 2458
    Re: Ricoh Aficio 350 ADF sponge rollers inside the belt falling apart
    I see:
    3x A548 1461 Belt Pressure Roller (located middle)
    1x A680 1451 Belt Pressure Roller (located left)
    1x A610 2161 Belt Pressure Roller (located right)
    All are including the shaft.
    You can also try polishing the glas plate with some sort of windshield rainEx if the machine need only a little life extension^^
    • patterson70
      • May 2010
      • 599
      Thank you greatly! Left you a Like and a Rep Power vote!
