MP301 - SC672!
  • Polarbear
    • Feb 2012
    • 1070
    MP301 - SC672!
    I have 2 of these animals in my workshop, and am running out of ideas.
    I have had both the controller and BICU of BOTH tested by our electronics workshop, and 3 of the 4 boards came back as tested fine (1x controller is unrepairable).
    What gets me is that the SC672 does still come up on strart-up, before the engine starts. I have looked over the point-to-point diagram to check that all the connectors are in the right places, but cannot fault anything there either.
    This does not make sense!
    Only other culprit I can think of is the PSU that is not supplying a line of power to the controller?? Any more ideas anyone?
    Press the GREEN button!!
  • jermyth
    Riso dude
    • Mar 2011
    • 441
    Re: MP301 - SC672!
    Pinched wire(s) between controller and op panel? Just a thought.
    • Polarbear
      • Feb 2012
      • 1070
      Re: MP301 - SC672!
      Just opened up the power supply and found that someone left me a nicely damaged unit! Machine still power up but once I had repalsed the psu, the error was gone! GRRR!
      Thanks for the suggestions!
      • Polarbear
        • Feb 2012
        • 1070
        Re: MP301 - SC672!
        Checked the power supply and found inine fuse (FU6) was blown.Replaced and all is well. Add this one to your notebooks!
        • Polarbear
          • Feb 2012
          • 1070
          Re: MP301 - SC672!
          Checked the power supply and found inline fuse (FU6) was blown.
          • mbcruzin
            • Aug 2013
            • 142
            Re: MP301 - SC672!
            Brand new out of box. SC672 error code. I am ordering or seeing if Ricoh will warranty a new board. I'll let you know what happens.
            • Francoi
              • May 2014
              • 4
              Re: MP301 - SC672!
              Are you sure ?....
              • mbcruzin
                • Aug 2013
                • 142
                Re: MP301 - SC672!
                Originally posted by Francoi
                Are you sure ?....
                No. Installed new PSU no change in code. Checked Voltages from PSU, and I'm getting my 5VDC and 24VDC to the BCU. I'm thinking replace the BCU or Controller next. Any thoughts?
                • apump
                  • Mar 2009
                  • 160
                  Re: MP301 - SC672!
                  About 2 months ago I had one that was the dims on the control board.
                  • bob marley
                    • Jan 2012
                    • 1339
                    Re: MP301 - SC672!
                    yesterday had the same problem , solved by replacing controller
                    Live for yourself and you will live in vain. Live for others, and you will live again
