Shortcat
  • PinevskiS
    • Jul 2009
    • 283
    Shortcat
    Can I create a shortcut on screen for Series Copies?
    If possible how to do it?
    Book 1 Sided
    You can make 1-sided copies from two facing pages of a bound original (book).
  • Jomama46
    • 2900
    Re: Shortcat
    Set the screen for the program, press Program, press a program button + OK.
    sigpic
    A+; Network +; PDI+
    • Eric1968
      • 2458
      Re: Shortcat
      Which model???
      Program all desired setting and press the button with the diamond/arrow on it and program one of the shortcuts.
      • PinevskiS
        • Jul 2009
        • 283
        Re: Shortcat
        I try now but nothing happens
        • PinevskiS
          • Jul 2009
          • 283
          Re: Shortcat
          Model MP 5002 sp
          • Jomama46
            • 2900
            Re: Shortcat
            from the operator manual
            sigpic
            A+; Network +; PDI+
            • techsass
              • Dec 2010
              • 248
              Re: Shortcat
              If you're trying to get it on the LCD screen, go to User Tools/ Copier Features/ General tab and press the Copier Functions button. I don't know if the feature you want is available, but that's where you can edit the LCD display choices.
                • 23008
                Re: Shortcat? or Shortcut
                We've had orangecats, whitecats, blackcats, taillesscats, but never a shortcat. =^..^=
                • nmfaxman
                  • 1702
                  Re: Shortcat
                  Set it up as you would every time you make the selections, the select PROGRAM, create new then name it.
