C 811DN Double Image
  • rreasonover
    • Oct 2011
    • 9
    [CQ] C 811DN Double Image
    Replaced color pcu's and ITB unit, fuser and blk pcu. Unsure whats causing this. Any help welcome.
  • JustManuals
    • Jan 2006
    • 9838
    Re: C 811DN Double Image
    Paul@justmanuals.com
    • skynetto
      • Sep 2012
      • 257
      Does the image remain double on the belt or it doubles exiting the fuser? Have you checked forced alignment of laser?
      • arahael
        • Mar 2013
        • 97
        go service mode, then do copy sp, 2111, b, c,
        • sandmanmac
          • 3981
          x 2 on that (Line position adjustment)
          But the order is actually 2111-3 (rough), and then 2111-2 (fine)
          • Cipher
            It's not easy being green
            • May 2006
            • 1309
            I'm not so sure that's a colour reg problem looking at the sample, it looks more like fusing offset.
            How thick is the paper stock are you using?
            Have you set the printer and print driver settings to the correct paper thickness setting?
            Could also be a printing error, sometimes layers in PDF file can cause weird over lap problems.
            Try exporting to different format or printing the file as a image.
            • Jomama46
              • 2900
              Run a black copy, that will tell you if its fuser or color reg.
              sigpic
              A+; Network +; PDI+
              • mikadonovan
                • May 2008
                • 2931
                I agree with this. Some boxes on the document are fine. Is this the only document they are having this kind of problem with?
                NEVER ASSUME ANYTHING
                • Iowatech
                  Not a service manager
                  • 3930
                  The line adjustment looks like it might help, the adjustment is pretty easy and you won't wreck anything by doing it even if it is unnecessary.
                  But it might be more helpful to upgrade or change the print driver, as it looks like the current print driver simply doesn't understand that concave font. If you can find it for this machine, get the latest RPCS driver. Otherwise, swap PCL 5 for PCL 6, or vice versa. Either way, make sure the driver you use is the latest version from the public Ricoh site.
                  (My experience with the "Universal PCL" driver has not been consistent enough for me to have a take on it. A good deal of the time it does works perfectly, but from time to time it has frustrated me to the point that I'd like to hit it with an axe. And that's probably just me, too, I'm probably doing something wrong. So check with others here if you want to use it, it could work.)
                  • ptrflrs
                    Glorified Parts Swapper
                    • Dec 2010
                    • 192
                    X3 on forced line adjust, BTW I've been told repeatedly by ricoh tech support to run "C" then "A" skipping "B" entirely but I have had good results in different orders. It is weird that some of the dark But not full black text looks fine.
                    jesus loves you! (everyone else thinks you're an assh*le)
                    street cred: CompTIA A+ & Network+ Certified; Konica Minolta Gold Seal x2,
                    Konica Minolta Outward ASSociate, Ricoh, Sharp, Lexmark trained
                    • rreasonover
                      • Oct 2011
                      • 9
                      Guys this fixed it! Thanks!
