Re: MPC 2500 Toner Problem
Put some toner manual into the devbox by a spone or something, if that works the problem is not the dev box.
Check the part where rubber hose fits on the toner end sensor remove it and clean..
BTw do you use orginal toner?
I have seen machines get waco with nonorginal toner and i had to replace ROM where pixelcount takes place.
