sc202 - MP5500
  • patrick_aab
    Junior Tech
    • 10
    [Error Code] sc202 - MP5500
    Just wondering if anyone has come across an sc202 error on these machines. machine gets power op panel has a dark screen with sc202 behind it. have replaced, Prism motor, IPU, I/O board, BCU and op panel individually and all together and still throwing up sc code on start up. any suggestions?
  • greyfox
    • May 2010
    • 20
    Re: sc202 - MP5500
    have you check the controller board?
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: sc202 - MP5500
      Pull open all the trays, disconnect all options and try again. You might have a chafing harness on the LCT.
      Hit it.
      • patrick_aab
        Junior Tech
        • 10
        Re: sc202 - MP5500
        Tried turning on with main door, all trays, duplex unit, fuser/exit unit open, df and finisher unplugged and still throwing up error.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Re: sc202 - MP5500
          In what order did you replace each part?
          • Imprestik
            • Aug 2012
            • 297
            Re: sc202 - MP5500
            1st, replaced the laser diode,
            if it is still coming up, replaced the eeprom on the bcu
            • patrick_aab
              Junior Tech
              • 10
              Re: sc202 - MP5500
              I replaced the prism motor and Ipu as a pair. Machine still threw up error. And then I replaced the bcu, IO board, operation panel, mirror motor and Ipu again all together at once still threw up the error code
              • 1nevster
                • Dec 2010
                • 49
                Re: sc202 - MP5500
                You should really replace the Polygonnal motor and the BICU at the same time, doing them in sequence will blow the board again in a lot of cases.
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  Re: sc202 - MP5500
                  This wouldn't possibly be a post by the infamous aab1 under another name by chance???????????????????????????????????????????? ?????????????
                  Mystic Crystal Revelations
                  • kimbo
                    Re: sc202 - MP5500
                    Did you find the solution?
                    as I am having the same issue
                    At one of my customers,
                    Going to replace the ipu board and poly motor as a pair,
                    Fingers crossed
                    • DIONISIS
                      • 17
                      Re: sc202 - MP5500
                      check LD UNIT-POLYGON MIRROR-LD REFLECTOR
                      DIO-masterprint
                      • kimbo
                        Re: sc202 - MP5500
                        Thanks DIONISIS replaced the PSU unit and the machine is working great now!
                        So I should have dug a little deeper to start with,
                        But thanks all the same!
