Lanier LD370 Fuser Web
  • dgrow
    • Feb 2011
    • 26
    [Error Code] Lanier LD370 Fuser Web
    Hello All,
    I have replaced a fuser web in a Lanier LD370 but the "replace fuser web" message keeps popping up. I am able to clear it temporarily but uit returns a short time later. I enter service mode and go into 1) Feed and clear the counter for web motor. The machine comes to ready and works for a while but then the message returns. Does anyone have any suggestions for me?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Lanier LD370 Fuser Web
    Make sure you have positioned the web end sensor correctly.
    • kyrenecopy
      • Apr 2012
      • 205
      [ATTACH=CONFIG]21643[/ATTACH]
      And make sure the acuator is not broke off or bent from heat. Reset the web counter, not the web motor!
      Testing 1-2-3, testing, testing. Is this thing on?
