Mpc3001 acc sheet
  • knobby
    • Oct 2008
    • 75
    [CQ] Mpc3001 acc sheet
    Anyone ever had this?
    print calibration sheets are fine, only the copier one is like this?
    print quality is fine...
    Scan quality is fine...
    Document server scan is fine...
    copies are blurry / grainy
    Help
  • skynetto
    • Sep 2012
    • 257
    Re: Mpc3001 acc sheet
    Check the settings on the birth certificate and verify that everything is as it should be.
    • knobby
      • Oct 2008
      • 75
      Cheers... Tried that and also nvram cleared, no joy
      • Polarbear
        • Feb 2012
        • 1070
        Press the GREEN button!!
        • knobby
          • Oct 2008
          • 75
          Thanks for the well thought out reply, its not line position though...
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            Have you reseated the RAM? In fact, what have you done?
            • knobby
              • Oct 2008
              • 75
              Push / pull everything on controller... Dimms... Cleared nvram twice...
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                • kannuki2
                  • Feb 2012
                  • 398
                  Does it do the same when you copy in Black/White and single color? If it's happening in full color copy then check the SBU settings from the birth certificate.
                  • kannuki2
                    • Feb 2012
                    • 398
                    Just a FYI, my team leader has this famous saying when we ran into tough problem with a color box, "replace all suspect parts BEFORE you perform a NVRAM clear, use it as a last resort." I regret it when I first start working on a C2500 and did a CRAM without a birth certificate. The machine ended up sent back to the warehouse and it took him a few weeks to fix it.
                    • teebee1234
                      • Jul 2008
                      • 1670
                      The few times I've seen backgrounding on copies only was when the gray balance was whacked. I don't know that it would affect the calibration sheet but you should give it a check anyway.
                      Background when ADS Mode is turned Off
                      In Full Color the background is a process black, In Black and White mode the background is gray. With ADS on there is no evident backgrounding. When ADS is turned off and exposure is at the center setting, backgrounding is exhibited. Print Jobs and internal prints do not have background
                      [Cause]
                      The gray balance adjustment NV RAM Data has been corrupted and has reverted to the default value
                      [Resolution]
                      Reset the value of SP 4685 - 001 and 002, SP4686 - 001 and 002 and SP4687 - 001 and 002 to the value on the Factory Data Sheet.(Located under Jam Instruction Sheet on the Front Cover)
                      If the Factory Data Sheet is not available try starting with these settings and fine tuning as needed.
                      • SP4685-001 to -26 SP4685-002 to -26
                      • SP4686-001 to -6 SP4686-002 to -6
                      • SP4687-001 to -16 SP4687-002 to -16
                      • knobby
                        • Oct 2008
                        • 75
                        Cheers all...
                        it was the BICU, swapped with office machine and fault went with it.
