Ricoh 2075, SC345
  • copyman
    Owner / Technician
    • Sep 2005
    • 4732
    Ricoh 2075, SC345
    This code will come up after making a copy. The copy is fine but throws code every time. If you turn machine off and back on it will allow you to make a copy but throws code again. I don't have the manual for this exact model but looking at other ricoh manuals is has to do with a toner lock up or developer?
    Anyone know what this means and how to correct it.
    Thank for the help
  • sandmanmac
    • 3983
    Re: Ricoh 2075, SC345
    Never dealt with it but, SM says this:
    SC345
    GG
    suggests these causes:
    SC 345 developement output abnormal, check for damaged harness by flywheel
    SC 345 Development Bias output abnormal - Tighten Drum shaft screw
    • Exok
      • Jun 2011
      • 750
      Possible causes: Development power pack defective, Development bias leak due to poor connection or defective connector.
      • Imprestik
        • Aug 2012
        • 297
        Clean your earth out on the dev unit, I think there are 3 on the rear of the dev unit. Also check in the cavity where they connect to, there may be debris in them
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • dpoutz
            • May 2011
            • 78
            flywheel screw loose or defective bias power pack is usually the fix
