mp 8000 image defect
  • jtymabel
    • Aug 2008
    • 164
    tried different drivers, pc. etc. replaced laser and polygon motor. updated firmware. problem still persist. need ideas.
  • Eric1968
    • 2458
    Re: mp 8000 image defect
    I would say a bad memory..
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      I agree, had this a few times with faulty memory modules. Give it/them a clean and reseat, if still occuring then a replacement is needed.
      • Iowatech
        Not a service manager
        • 3930
        The SBU is bad.
        • vargue
          • Oct 2011
          • 404
          please more details .this problem in printing or copying or scanning .and did yo hear noise while doing that .like gear crack or some thing like that
          • gasior78
            • 29
            Worth checking the interlock switch too.
            • jtymabel
              • Aug 2008
              • 164
              no noises. copying works fine. i actually thought it was the document. i was appearing always on the last 3 pages of a document. (same pattern). Sometimes is black thick lines, sometimes its 1" band with horizontal lines. its always towards the end of the document. i will try the memory modules.
              • Iowatech
                • 3930
                Copying works fine? Well, that makes my previous post totally wrong, sorry about that.
                On the other hand, the machine prints OK except for the last three pages of a print job? If that is the case, it is quite unlikely the machine is the problem. The machine is just printing the data sent to it by your computer after all (if there was an issue with the machine, everything you printed would look the same), and as such it is far more likely to be an issue with the application you are printing from.
                • sandmanmac
                  • 3981
                  Does it happen with all connected PC's? Is it only 1 specific document, or everything? Have you tried another driver? Firmware?
                  • Tonerbomb
                    AutoMajical Resolutionist
                    • Feb 2005
                    • 2589
                    I agree with sandmanmac!!! test other pc's or better yet put that file on a laptop and print via crossover to see of you can recreate it...............
                    Mystic Crystal Revelations
                    • zames77
                      Tweak it till it breaks!
                      • 121
                      I've had a few weird CQ issues that have been sorted with a new BICU. I'd give that a go first.
                      • jtymabel
                        • Aug 2008
                        • 164
                        its actually different documents from different pcs (there are a total of 6 in the office). they only thing they have in common is the application they use (creates pdf's) and the mp 8000.
                        i uploaded a pdf from my google drive and tried printing it. It had the defect. I uninstalled acrobat from 3 pcs and installed the latest acrobat reader. Still no luck. I installed a pcl 6, pcl 5e and ps driver with no luck.
                        • jtymabel
                          • Aug 2008
                          • 164
                          i will try memory and bicu.
                          • jtymabel
                            • Aug 2008
                            • 164
                            Replaced memory and BCU...
                            PROBLEM FIXED.....
                            Thanks for the help
