Savin 8035 Misfeeding
  • tcypy1961
    • 773
    What would cause this copier to misfeed in tray 2 only? The misfeeds only occur when the paper is being pulled in 11 x 8.5. I've never seen it occur when it is pulled in 8.5 x 11R. The copier did have 9 misfeeds with code 013 size 26H. It also had 1 misfeed with code 059 size 26H. Any help appreciated, thank you.
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: Savin 8035 Misfeeding
    How 'bout the tray 2 feed clutch, or the vertical transport roller being dirty???
    Mystic Crystal Revelations
    • sandmanmac
      • 3981
      Just wondering..you have a simple misfeeding problem and you're stumped? You haven't tried anything to resolve it? Sounds pretty basic as Tonerbomb suggested.
        • 37533
        The 8035/8045 does not have auto paper size detection. Since it jams with one orentiation of the paper and not the other, check the paper size dial at the back left corner of the paper drawer. You can also look at the panel. The orientation shown on the panel should match the oriention of the paper in the drawer. If the size dial is set correctly but the displayed orientation does not match, the size switch could be defective. If it always shows the same size on the operation panel, someone may have compensated for a defective size switch by setting the size in the User Tools.
