MPC 2800 duplex-jam J025
  • Zeldaman
    • Mar 2011
    • 946
    Hi there!
    Had a very nice problem. Allways J025 when duplexing, paper allways and exactly at this position20130909_150050.jpg
  • afat
    • Sep 2017
    • 11
    Re: MPC 2800 duplex-jam J025
    Originally posted by Zeldaman
    Hi there!
    Had a very nice problem. Allways J025 when duplexing, paper allways and exactly at this position[ATTACH=CONFIG]22020[/ATTACH]
    I also had this problem, i try change the motor also not working....have another solution?
    • davel
      • Oct 2011
      • 1107
      • afat
        • Sep 2017
        • 11
        Okay thanks you sir, i try first
        • GIUBOSS
          • 1436
          D0294492 Fusing Entrance Guide Plate, if it's old, replace it
          • GIUBOSS
            • 1436
            if it's old, replace it: D0294492 Fusing Entrance Guide Plate
            • sandmanmac
              • 3981
              The initial post is most likely a different problem than yours. The cause of duplex jams in these units is pretty common in my experience, and is almost always due to gate being warped from the heat of the fuser.
              • skinnyb
                • Jul 2008
                • 291
                [ATTACH=CONFIG]44053[/ATTACH]
                Agreed. I have replaced several over the years. The old ones warped easy. They redesigned the part and put a metal shaft in the center for support. Those work much better.
                Sent from my LM-V405 using Tapatalk
                • skinnyb
                  • Jul 2008
                  • 291
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Like this post you mean?
                    • Zaxxon
                      • 608
                      Please start you post with brand, model, problem.
                      • usta
                        • Oct 2013
                        • 44
                        replace the roller gears for turning the belts at the edges of the duplex.
                        • usta
                          • Oct 2013
                          • 44
                          b223 4529
                          b223 4514
                          b223 4535
