MP C4500 Strange start-up
  • jrob416
    • May 2011
    • 112
    [Misc] MP C4500 Strange start-up
    Recently formatted the hard drives on a MP C 4500 and everything came back on line fine. The next day the customer had to restart the machine and the finisher did not reset its position at power on. The copier also did not beep when it came ready. Has anyone heard of this before. Thanks.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MP C4500 Strange start-up
    When you say formatted, did you do it on a PC or directly in the copier?
    • jrob416
      • May 2011
      • 112
      With a PC. The copier would not allow a format, could not get to service mode.
      • bobbykerr
        • Sep 2012
        • 52
        Have found that you can usually get into service mode from an unresponsive m/c by powering up with the side door open
          • 37481
          Unless the machine administrator has turned on Service Mode Lock in User Tools.
          • JustManuals
            • Jan 2006
            • 9838
            This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
            Paul@justmanuals.com
            • Polarbear
              • Feb 2012
              • 1070
              Generally we also format HDDs with a pc adapter when the machine will not.
              I have to date not come across this on any of our machines.
              I know in service mode - under option 6 (Peripherals) you can do a connection check to check if the machine "sees" the finisher.
              It might also be worthwhile to reformat the disk in the machine and download the stampdata (as per the FSM) if this model has stamp data to download.
              Then give it another try.
              Press the GREEN button!!
              • jrob416
                • May 2011
                • 112
                Replaced both HDD's and problem went away. One of the HDD's had been damaged in a past life. Thank you to everyone who responded.
