Resetting Nvram M48T129V
  • Codex
    • May 2008
    • 704
    Hello
    I want to know if there is a way to reset a Nvram Timekeeper M48T129V or similar.
    Thank you
    Memento Audere Semper
  • decimal
    • Aug 2006
    • 75
    HI !
    you want to reset it for what ? Total counter ? It' s legal
    • Codex
      • May 2008
      • 704
      Hello
      I work for a company that sells and lent copiers (pay per copy), if we buy a copier we replace all PM Parts, and the belts inside, after that we clean the maschine completely, from outside and inside, this works takes 2 or three days. After this operation we give a full 3 Year warranty on every part, because the maschine de facto is new, thats how we will reset the NVRAM.
      There are other companies here in Italy that do the same.
      • Bizhub
        • 147
        We may be able to help you.
        Email bizhub@mail.com
        Regards
        • Codex
          • May 2008
          • 704
          Regards
          Hello
          You have an email....
          Thank you
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            Originally posted by Codex
            Hello
            Thank you
            mail@bizhub.com
            • nobody-here
              • Mar 2008
              • 237
              Hello,
              what Copier is that NVRAM? You can buy new one from Ricoh, because if you reset NVRAM you loose all the default programming, you need to recall all the settings... without them the machine will not work properly.
              29 rouge unpair manque.... cous cous....
              • Codex
                • May 2008
                • 704
                Originally posted by nobody-here
                Hello,
                Hello
                Ofcourse i make a Backup befor i reset the NVRAM
                • decimal
                  • Aug 2006
                  • 75
                  HI Codex
                  I don't understand , if you can back up it then you simply back up a new one and restore to the others with a programmer ..you don't need anymore , do you ?
                  • iMind
                    • Mar 2008
                    • 1116
                    Originally posted by decimal
                    HI Codex
                    You didn´t understand, he must upload system settings to a SD card, replace the NVram and then download system settings to the machine, these setting are the factory default (or not) when you make a memory clear it resets all the settings except the total counter, thats why he wants a (NVram) chip programer, but this just going to have to bye a new one, there are ricoh machines that have NVrams with a battery, on those you can desolder the battery and it will loose the total counter but then you´ll have to insert the machine serial number, in some cases is easy, its a part in service SPs in other cases theres a special service mode that I certainly will not tell you. Sounds complex but its not. another thing when you upload the system settings to SDcard it creates a file, if you explore the file on a computer WIN or MAC you´ll see that the files name is the machines serial number.
                    M48T129V this seams like a MP2000 2500 or 2550
                    • decimal
                      • Aug 2006
                      • 75
                      With a programer you can erase,rewrite or copy a NVRAM very easyly .
                      In fact ,i don't like resetting total counter .
                      • assvlad
                        • Dec 2015
                        • 17
                        Re: Resetting Nvram M48T129V
                        Hello. There is an M48T20, it has an M4T28 battery installed. Battery dead. Replaced with a new battery. This board is in the Xerox Nuvera 288 machine. The machine does not work. Is there a way to reset M48T20?IMG_20220317_111431.jpgIMG_20220317_111443_1.jpg
                        • GIUBOSS
                          • 1436
                          Originally posted by assvlad
                          Hello. There is an M48T20, it has an M4T28 battery installed. Battery dead. Replaced with a new battery. This board is in the Xerox Nuvera 288 machine. The machine does not work. Is there a way to reset M48T20?[ATTACH=CONFIG]52556[/ATTACH][ATTACH=CONFIG]52557[/ATTACH]
                          this Thread is now in the afterlife, it would be better to start a new one ....
                          • assvlad
                            • Dec 2015
                            • 17
                            thanks. created a new topic
                            • luca72
                              • Oct 2017
                              • 1784
                              Hello
                              we have a supplier, who sells us remanufactured machines with nvram reset (just 200-300 test prints before being shipped)it seems to me that it also sells nvram reset, I have to try to ask my boss, it seems to me about 60-70 euros, but I'm not sure
                              "I'll be back"
