Jam on exit, Finisher SR 970
  • Codex
    • May 2008
    • 701
    [Jamming] Jam on exit, Finisher SR 970
    Hello
    i have a strange problem on two SR 970 finisher.....both jams on paper exit (upper and lower exit), making a very bad noise, sounds like some vibrations comming from the motor...i swapped the motor with one from another working SR 970 , but still the same problem.....the paper comes out only a half.........then jams, and this noise...
    sometimes it works for 30 or 40 copies, but when i touch the exit roller it stopps immediately making the noise
    some idea?????
    Thank you
    Memento Audere Semper
  • mikadonovan
    • May 2008
    • 2931
    Re: Jam on exit, Finisher SR 970
    You need to print a smc report. It will tell you a jam code pointing to the culprit sensor.
    NEVER ASSUME ANYTHING
    • Iowatech
      Not a service manager
      • 3930
      Originally posted by Codex
      Hello
      some idea?????
      Thank you
      Lube the roller bushings with a high quality penetrating oil, because they are binding.
        • 37449
        Bushings also.
        • CableGuy
          Impulse Drive Engineer
          • Oct 2008
          • 417
          Probably not much help, but I've had all kinds of things break in these. Check all the stays and shafts are where they are supposed to be and not flopping around inside.
          • digicor
            • Jul 2008
            • 1153
            I have your solution,, replace it and throw away the old one, these get worn out and break in all kinds of weird things happen
            the lift tray gear could be cracked and intermittently coming apart at stress times...
            • Eric1968
              • 2458
              99.99% that the bushings cause this. Just had the same last week. The bushings are getting full of dirt and that causes the exit motor to make the vibrating noise, and causes the jam. As stated above, cleaning and lubricating them will solve it.
              • Ronan
                • Aug 2011
                • 55
                Hi I have had a similar problem with some models finisher, searching I found that the problem was the old firmware I had, the machines were used and the seller had changed the finisher. so update the firmware and fix the problem that the paper was stuck in the middle of the output.
                I hope you can help
                • Codex
                  • May 2008
                  • 701
                  Thank you all!!!
                  i'll try your solutions and let you know!!
                  • Codex
                    • May 2008
                    • 701
                    SOLVED!!!!
                    lubricating the bushings worked for me!
                    Thank you guys!!
