Hey,
Last month I had have 2 identical problems, on a aficio 2232C and a aficio 3245C. The color was shifting, and color registration was not possible.
The sp modes are a bit different on both machines, but the process is not so different.
I folowed the next steps:
* checked all pcu's and dev. boxes, and cleaned/replaced what was necessary (also Id)
* checked and updated latest firmware.
* made a process control to check all units (1111)
* tried to make a forced line adjustement (nogo) 070707
* changed the values in mainscan and subscan manually, while checking the lines on the transfer belt without cleaning.
* replaced the transfer BELT (nogo)
* replaced Id sensors (nogo)
finally in both cases the problem was solved by replacing the whole transfer UNIT. After all, the customer is happy, but both transfer units had made around 250k, that is much less than the life time.
If somebody had have the same issue, please let me know if there are other solutions to fix this problem. Maybe a little part on the transfer unit could be the problem, maybe not.....let me know.
Kind regards,
Froota
Kind regards,
Froota
