Hi All
More problems today.
The MPC 2500 was doing a small print job when I became aware first of a rustling crumpling sound and a smell of overheating. It then stopped printing with the SC553 error code.
Reset the code and switched back on, again the same results.
Had a look at the fuser and the fusing belt has an area of crumpling/ dimpling about 70mm wide opposite the thermistor all the way round the belt and its these crumples that are causing the noise. I assume that the thermostats have failed causing the heating roller to overheat and causing damage to the belt.
My question is whether its worth trying replacement parts- thermostats/ lamps/ fusing belt or looking for a new fuser assembly or put it in a skip and buy a new photocopier. I paid £650 for it a year ago. If it wants £500 spending on it I may as well cut my losses.
Serial no L3683700586 counts are total colour 53714, B/W total 176536.
As always your advice will be gratefully received.
And dsdigitalprint I will be calling you next week if the consensus is for a repair.
Many thanks
Alan
Many thanks
Alan
