MPC2500 fuser problems
  • kurnal
    • Sep 2012
    • 12
    Hi All
    More problems today.
    The MPC 2500 was doing a small print job when I became aware first of a rustling crumpling sound and a smell of overheating. It then stopped printing with the SC553 error code.
    Reset the code and switched back on, again the same results.
    Had a look at the fuser and the fusing belt has an area of crumpling/ dimpling about 70mm wide opposite the thermistor all the way round the belt and its these crumples that are causing the noise. I assume that the thermostats have failed causing the heating roller to overheat and causing damage to the belt.
    My question is whether its worth trying replacement parts- thermostats/ lamps/ fusing belt or looking for a new fuser assembly or put it in a skip and buy a new photocopier. I paid £650 for it a year ago. If it wants £500 spending on it I may as well cut my losses.
    Serial no L3683700586 counts are total colour 53714, B/W total 176536.
    As always your advice will be gratefully received.
    And dsdigitalprint I will be calling you next week if the consensus is for a repair.
    Many thanks
    Alan
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC2500 fuser problems
    You will only need to replace the fusing belt. I would also recommend replacing the pressure roller bearings, the heating roller bushings and bearings.
    • Eric1968
      • 2458
      And dont forget the Oil Supply Roller and the Cleaning Roller.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • kurnal
          • Sep 2012
          • 12
          Thanks. Am I right in thinking a thermostat problem is the likely cause of the overheating? Should they be replaced too?
            • 37487
            Thermostat no. Thermistor and thermopile yes. Either bad, dirty, or out of position.
            • Eric1968
              • 2458
              The thermostats cut the power from the fusing unit when the temperature reaches 210 or 220 degrees Celcius to prevent damage to the machine. The thermistors control the temperature and tell the machine when to switch on/off the lamps.
              • kurnal
                • Sep 2012
                • 12
                Thanks for that. I could smell overheating and the belt was damaged so it probably points to defects in both the normal control system and the over temperature controls. Wouldn't be much fun to replace the fuser for the same to happen again! That's why I shall be asking a pro to fix it for me if I can.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  With these fusers the last thing you want to do is skimp on parts, regardless of how much it costs. Get the tech to rebuild the ENTIRE fuser, including belt, hot and pressure rollers, bearings, bushings, oil supply/cleaning rollers and thermistors. That way, if you keep refreshing the oil supply roller approximately 150k, this fuser will run for at least 400-500k.
                  Hit it.
                  • Dhearn
                    • 24
                    Use PMB230160k Pm kit for the fuser
                    • kurnal
                      • Sep 2012
                      • 12
                      Thanks to all for your good advice as always. Please would any competent tech who contributes to this excellent forum and is prepared to take on this repair for me along with any future servicing (we are located between Matlock and Bakewell, Derbyshire) please give me a call on 078-76-545-705 delete the -. I could take out the fuser assembly and deliver to you by courier for rebuild provided you come back once it is done to check the machine over.
                      • kurnal
                        • Sep 2012
                        • 12
                        • sandmanmac
                          • 3981
                          Long periods of non-use of these machines will cause the rollers and belt to become deformed since they're under constant pressure -particularly if they're kept in a cool environment. I've seen more than one belt shred, when it's been powered up after several months of non-use.
                          I'd recommend removing the unit from the the machine if it will not be used for an extended period.
                          • Gift
                            • Mar 2011
                            • 2459
                            That`s totally odd - an entire new fuser should last way more time/prints. You're shure it was brand new and not some sort of refurbished stuff?
                            When we refurbish the fuser we like cutting some corners here and there but usually swap the press roller thermistor even if it's not part of the "official kit". On most MPC2500 fuser you'll notice that the thermo element (a little black spot) loosen from the teflon-coated metal plate leading to bad readings.
                            • Klydon
                              • Mar 2009
                              • 243
                              Sand has it likely right.
                              Some questions for kurnal: On your small job, is this going on normal paper or would it be a different type of stock or thickness? If different from normal paper, are you changing the settings on the machine to reflect what you are printing/copying on?
                              The fusers for these machines are good fusers and will last quite a long time in most cases from what I have seen and experienced.
                              Since you are at another decision cross roads, I guess part of the question is how much use you think the machine may get over the next year or two. This machine model is getting long in the tooth and I don't know how long before parts availability may start creeping into the equation. In addition, if you are not running much volume, you may be able to downsize on your next machine (get a newer/smaller machine).
