Hi all
I have a problem with this m/c in duplex mode using df ,duplex to duplex is fine,in platen mode is fine but when copying single sided to duplex the second side has a thin dark line 8mm down and parallel to the lead edge and the registration is off by that amount.Thanks in advance.
