Aficio1022 - Error Code SC541.....then Error Code SC542
  • TonerMunkeh
    Professional Moron
    • 3865
    #16
    If you've done a 5801 and the machine hasn't run a copy since, that's why all those SP's are at zero. You could just replace the lower fusing frame (B0274072 I think) and the thermostats instead of buying a new fuser.
    Hit it.
    • ritchiewheeler
      #17
      Re: Aficio1022 - Error Code SC541.....then Error Code SC542
      Thanks everybody for your help! It's great to see people offering assistance to others out of good spirit when problems arise.
      Ritchie Wheeler
      • Codex
        • May 2008
        • 694
        #18
        Is the Fuser Roller Original????, i had a similar problem with Katun Fuser Rollers, they was a little bit thicker that the original, causing SC 542+SC 541
        Memento Audere Semper
        • m2digital
          • Dec 2013
          • 19
          #19
          Does the Hot Roller get hot/warm at all?
          If it's cold and the lamps + thermofuses are OK then the fault is on the Power Supply board.
          • Iowatech
            Not a service manager
            • 3930
            #20
            Actually, it kind of sounds like the part of the fuser casing that holds the rear hot roller bearing in place has broken.
            There is at least one entire thread on that subject that I had bookmarked, but the computer the info was on died recently so I don't know where it is right now. Sorry.
            • CrapAimer
              • 296
              #21
              If you have Changed the Thermistors, and the Thermal Fuses if the lamps are ok then you have a power supply problem. Very rare but have had it when screw came out and shorted the fuser, blowing the power supply.
              • jha1970
                corona copy solutions
                • 2
                #22
                2 stats in series,
                one goes open the other doesnt,
                simply give the back of it a clout then peform 5810 in service mode
                • aiam
                  • Oct 2013
                  • 15
                  #23
                  for testing purposes, take out the thermal fuses and close the circuit with a clip, if it works you know if the problem is about the thermal fuses. at least you eliminate one probable cause..
                  • Eric1968
                    • 2458
                    #24
                    This can be very dangerous!!! The thermostats are installed there to cut the power to the lamps to prevent overheating! Doing this can cause major damage to the machine!
                    • aiam
                      • Oct 2013
                      • 15
                      #25
                      i know, but i do this only to see if the machine boots without sc codes.
                      • aiam
                        • Oct 2013
                        • 15
                        #26
                        and in this case, the machine already have suffer damages :P ahaha
