background on colorcopy but not print jobs
  • javaman7471
    Service manager/Tech
    • Jan 2012
    • 16
    I am working on an Ricoh MPC4500 that will have a pinkish/gray background on color copies but internal print jobs look fine. I was told that an all clear was performed in SP mode and I do not have birth certificate for machine, is there any way to return it to normal functions. Any help is appreciated, thanks.
  • turbojetboy
    • Aug 2009
    • 279
    Re: background on colorcopy but not print jobs
    Thats classic all clear problem, probably got bad colour alignments and tray regos and a bunch of other stuff out as well. Best bet would be to get another birth certificate (from another mpc4500) and pay close attention to all the shading values and items relating to the scanning section. Good luck.
    Doing an all clear without first backing up the NVram data to SD card is one of the most stupid things a tech (or other) can do.
    PS: you did check behind the jam location cover thats attached to the front main door for the birth cert - didnt you?
    • javaman7471
      • Jan 2012
      • 16
      Yes I checked behind jam removal chart on front door, so if I can get another birth certificate from a different machine which settings in particular will I need to look at. Previous tech did do the all clear without backing up any data, that is correct. Thanks again. JV
      • rsyarcia
        Hair Straightener Tech
        • 711
        start in performing the force line adjustment
        Nobody is perfect..
        • javaman7471
          • Jan 2012
          • 16
          Color registration is not off colors line up great, just has a background, also if I reduce to 65% background is only in image area, white around reduced image is perfectly white still.
          • neergish
            • 177
            Is there a change when you have the Auto density sensor turned off or on?
            Reset the SP 4689m 4686, 4687 - 001 and 002 to whats on a birth cert, other wise fiddle randomly with these setings until you get it right. there s a thread on this somewhere here but I'm too lazy to search.
            "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
              • 37738
              One of the things that we do here on every service call is to always print the Non-default report SP 5990-006 on machines where it is available. Otherwise, we print the SP settings. Always save at least one from every machine. Can be used in the absence of the birth certificate.
              • ruben
                The New Guy
                • Oct 2012
                • 1205
                No two machines are alike, but you can use another as a base for reinputting the cleared settings.
                • Exok
                  • Jun 2011
                  • 750
                  Sometimes the simple solutions are what people forget. Make sure your optics are clean.
                  • Counsel
                    • Aug 2011
                    • 533
                    Not sure if this model does it or not but on some of the new models now Ricoh made a spot for the birth cert behind the scanner white board, if you might just check, remove the white board and look in there.
                    • Polarbear
                      • Feb 2012
                      • 1070
                      http://www.commercebusinesssystems.co.uk/support/
                      +1
                      Sent from my GT-P7500 using Tapatalk
                      Press the GREEN button!!
                      • techsass
                        • Dec 2010
                        • 248
                        It's been awhile since I've seen this and I always had the Birth Cert, but what you want to adjust is the Gray Balance - Book. It defaults in the 40s and you want to set it in the 60s. There's 2 or 3 Sp's for this in the upper 4xxx of Sp mode.
                        Sorry I can't remember which ones exactly as I just compared it to the Birth cert.
                        • Bantams
                          • Jun 2012
                          • 603
                          4685-1 to -73
                          4685-2 to -73
                          4686-1 to -58
                          4686-2 to -58
                          4687-1 to -66
                          4687-2 to -66
                          the above should work I carry a copy of the Factory sheet in my folder For times like this.
                          • Eric1968
                            • 2456
                            Techs that perform Memory Clear to resolve paper jams, print quality issues, service calls, etc. (and don't make a backup), don't understand sh*t about what they're doing and should be banned from this business forever!!
                            • Polarbear
                              • Feb 2012
                              • 1070
                              I so agree! There is one i.t. Tech with us who always jokes about memory all clear as if it is his secret weapon! Wish i knew who taught him the service mode access code! He should be shot!
