mpc2500 error code sc 868-02
  • BATA
    • Mar 2012
    • 27
    [Error Code] mpc2500 error code sc 868-02
    welcome , this error code sc 868-002 in ricoh mpc2500 happen after power on , from the s manual
    says its a device problem , either SD card or the controller. I tested the controller with its blue SD card and hdd
    in other good mpc2500 machine its working normal . so the problem lie in another place other than the controller,hdd ,or SD card . so can you guide me to the correct fault,thanks
  • copier tech
    • 8174
    Re: mpc2500 error code sc 868-02
    Have you tried flashing fw to latest version?
    • BATA
      • Mar 2012
      • 27
      where I can find the firmware , and SD card for flashing?
      • Bantams
        • Jun 2012
        • 603
        If it as a SD CARD reader attached to the machine disconnect it and try again.
          • 37533
          If the machine has had JAVA installed, someone may have turned the machine on after removing the JAVA card without first stopping JAVA, which can blow the controller board and the JAVA card. Per Goose's Guide, check the following Technical Service Bulletins: B230-009 and B861-002.
          • pattyboy7
            • Mar 2014
            • 21
            The controller won't blow wthout the java card in. I'm guessing you still uninstall java before you update the firmware.
            Try unplugging the HDD and powering it up.
