SP3510 Service Mode
  • copier tech
    • 8144
    SP3510 Service Mode
    Just a quick question, can someone tell me how to access service mode on this model, I want to reset the fuser count etc, I have searched the service manual but knowhere does it say how to enter service mode!!!???? It simply says enter service mode then maintenance menu etc
  • Debs1964
    • Oct 2010
    • 1693
    Re: SP3510 Service Mode
    Clear/stop, 107, Press & Hold Start, you must hold each button down until you hear a beep
    There are 10 types of people in this world, those who understand binary maths and those who don't
    • copier tech
      • 8144
      Hi,
      Thanks for your reply reply! but this is the SP3510DN, not the model with the scanner etc (see pic below) so it doesn't have a keypad!?
      • Moza
        • 232
        You need to download Smart Organising monitor from Ricohs website. This allows you to reset SC codes on printers
        http://www.ricoh-support.com/enduser/support/supporturl.asp?url=https://www.my-ricoh.com/enduser/AD3063EB-90E2-4BC7-A6DC-ACB1547D9655/brand/BF120732-CE83-453E-AAEE-7DAC0A646E6F/?lang=1
        • copier tech
          • 8144
          Cheers, many thanks
          • Eric1968
            • 2458
            Press the up and down arrow for more than 5 seconds and then press OK.
              • 37489
              SERVICE PROGRAM MODE - ENTERING ENGINE MAINTENANCE MODE Section 5.1.2 of the service manual. Either you do not have a service manual or you did not look very close.
              • copier tech
                • 8144
                Why would I lie about not having the manual!?
                My copy of the manual doesn't have section "5.1.2"
                  • 37489
                  What you showed pictured is totally different from what I downloaded from Ricoh-USA tech support site. From the manual that I have: Turn the power off. While holding the <Stop/Start Key> and <Escape Key> at the same time, turn on the Main Power Switch to the “ON” position. This and what Eric posted are the two most common method for entering service for Ricoh printers that do not use the Smart Organizing Monitor utility that Moza mentioned.
                  • pattyboy7
                    • Mar 2014
                    • 21
                    Hold up+down arrows for 5+ seconds then hit Enter/Select. go to engine and you have hacked the system
                    • TitoMartines
                      Thank you. This way fixed problem. By the way there is no this method within a field service manual on SP3510DN.
                      • copier tech
                        • 8144
                        Yes this is not mentioned in the service manual, how daft!
                          • 37489
                          It is shown in the latest manual available in the US date 5-24-2012.
                          • rhe
                            • Feb 2013
                            • 51
                            press escape and stop clear key then turn on the printer.
                            keep pressing both keys till service mode appears, select fuser SC rest and scroll for execute then press OK key.
                            • rhe
                              • Feb 2013
                              • 51
                              keep pressing both keys till service mode appears, select fuser SC rest and scroll for execute then press ok key
