MPC4503 and 5503 paper curling
Re: MPC4503 and 5503 paper curling
There are 10 types of people in this world, those who understand binary maths and those who don'tComment
We have one with an internal finisher causing jams finally put a bridge unit in and ext finisher now ok no jams but cant leave finisher there for free!!Comment
Good morning everyone.
I have been having the same problems. And now that winter is here, major problems will arise. I have hundreds of equipment Metis series.
The suggestion to activate the SP 5805 applies only in the case of equipment that have the "Anti-Condensation Heater". If you do not have this option enable this SP is useless.
The equipment installed in the south of Europe "Anti-Condensation Heater" is optional.
I agree that this is one of the solutions to the problem, however a change in the output paper tray decreasing the drop of the paper will be less expensive
I've found that if the machine has a bridge unit and the decurlers are not fitted at run up you'll have issues.....they only lessen the issue though.Comment
Ok my friend ... I know what ALL means ...
If I'm asking is because there is a strong reason for this.
I have hundreds of machines installed yet have a customized system/copy firmware...
This is the reason... Thats way I insist on asking what the firmware fixes the problem.
But ... thanks anyway ...Comment
Hi there!
Seems like the solution is in the rollers of the exit unit.
Latest news, change the exit rollers for the new exit unit rollers of the New device Corona to prevent the curling issue.
I Already have 1 device in a test environment and at the first look seems to work...Comment
Hi there!
Upgrade customer to an '04' series they have an anti curling bar built into the fuser!
This just shows that Ricoh were aware the '03' had this issue & addressed it!
Or a simple instant fix is simply using thicker paper, yes the customer will complain that 90/100gsm paper is more expensive but a good engineer will be able to explain the advantages.Let us eat, drink, and be merry, because tomorrow we may die!
