Ricoh 3713 fuser problem
  • NaVi247
    • Jul 2025
    hi guys,
    i'm new here, i need help on my ricoh 3713, whenever i make copies, i get a J2 error code, i found out that the fuser lock up and did not roll, i don't have any silicone oil here so i use 3M lubricant, it works, but for a mean time only. after few hours, it jammed again. plesa help. thanks
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Originally posted by NaVi247
    hi guys,
    This is a easy one for rookies, change the fuser rollers and bushngs, check exit sensor feeler that goes to the back side of your machine, it may e getting stuck, if not, change the sensor that works with that feeler it is on the top rear end when you open the exit door.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      try to clean first the fusing unit using check fusing gears... verify the life of your rollers perhaps they need to replace....
      fix the customer first then fix the machine... its simple and makes life more easy.
      • schooltech
        School District Tech
        • Jun 2008
        • 504
        Taking out the fuser is a little different than most of our newer machines.
        Since you need to remove the fuser, rebuild and reinstall, make sure that you reinstall the fuser tabs UNDER the frame tabs. Also, while the machine is fully clamshelled, remove and clean the drum drive spring-loaded coupler gear (by the drive motor.)
        It's not too hard to remove the fuser, just pay attention to how it is in there before you remove it. And, make sure that the machine is properly stablized when you go to remove the stops to open the machine 90 degrees.
        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
        • Jomama46
          • 2900
          And remove the developer and cleaner unit before opening the clamshell all the way..
          sigpic
          A+; Network +; PDI+
          • NaVi247
            thanks for the replies.. been out of town, i haven't check my unit yet but i will, thanks...
            • NaVi247
              thanks guys, got the unit working again, looks like i need to replace the rollers this time, the left part of the output don't fuse well...
