MP2001L copies with background
  • PA3040
    • Jun 2014
    • 171
    Dear All,
    I found MP2001L few machines that has a problem, copies get background ( like over toner )even copy counter not more than 20,000
    I replaced developer then problem is solved and after another 5000 copies the problem is papering again
    Does any one have similar issue and solution
  • Zeldaman
    • Mar 2011
    • 946
    • rsyarcia
      Hair Straightener Tech
      • 711
      Re: MP2001L copies with background
      use orig Ricoh Toner.
      Nobody is perfect..
      • Polarbear
        • Feb 2012
        • 1070
        Which dev are you installing on first startup? B1219645 (dev28) or B1589645?
        The latter is the correct one as it uses different toner to the previous models.
        Press the GREEN button!!
        • PA3040
          • Jun 2014
          • 171
          Yes, I used only OEM Toner and Developer
            • 37556
            He asked which OEM developer, by part number, did you use! Type 28 part number B1219645 or the correct developer part number B1589645! Also just because an item may say OEM on it does not mean that it is OEM for the machine your are using. If you did not order it from Ricoh, it might not be Genuine Ricoh.
            • PA3040
              • Jun 2014
              • 171
              I used D1589640
              What is the 9645 Number? We used always OEM 9640 Number
              Ex
              Product code Number
              D158 9640
              B121 9640
              • PA3040
                • Jun 2014
                • 171
                Or..... Thanks for the advice
                • Polarbear
                  • Feb 2012
                  • 1070
                  B1219640 is an older dev. It was replaced by the "45" dev = dev 28 around when the mp2000 was launched. It also, according to our price list, costs more for the older dev, even though the volume is the same.
                  Sent from my GT-P7500 using Tapatalk
                  • PA3040
                    • Jun 2014
                    • 171
                    Highly doubtful
                    Are you sure?
                    As per Ricoh B1219640 for MP1600/MP1800...etc ( product name kir c3 / kir c3.5..... )
                    and
                    D1589640 for MP2001L / MP2501L .....etc ( product name kir c4 ....)
                    It is impossible OEM developer number digits ending with "9645"
                      • 37556
                      Highly doubtful
                      Are you sure?
                      Very possible and very common. When initially released, developer part number will in 9640. When a change is made in the formulation, the new part number will in 9645. The second change will end in 9646.
                      • copier tech
                        • 8192
                        This makes sense as the latest fuser sleeves end in 46?
                        • PA3040
                          • Jun 2014
                          • 171
                          Thanks for the reply
                          In your reply, you are assuming. so I would asking actual
                          Up to now Ricoh do not have this kind of part number "9645"
                          If yes, how would you prove it
                          Please advice
                          thanks in advance
                          • copier tech
                            • 8192
                            Log in to your Ricoh support page & look for any parts manual updates, it will be there
                              • 37556
                              According to Tech Service Bulletin 012 for the MP2000, B1219640 is for use in Asia only. B1219645 is for use in North America and Europe. As for the MP 2001L, it was not made available in the United States so I cannot get any manuals or bulletins to check.
