MP2001L copies with background
  • copier tech
    • 8192
    #16
    Re: MP2001L copies with background
    According to Tech Service Bulletin 012 for the MP2000, B1219640 is for use in Asia only. B1219645 is for use in North America and Europe. As for the MP 2001L, it was not made available in the United States so I cannot get any manuals or bulletins to check.
    I just checked & D1589640 is the latest part number in the UK & is correct for the MP2001
    • PA3040
      • Jun 2014
      • 171
      #17
      Now Developer Part number problem is solved but my original problem is pending
      Any solutions
        • 37556
        #18
        Any solutions
        First, get the proper developer. Before you put it in, check for toner filming on the development roller. Clean it while there is no developer in the unit. If you think you might have a toner density sensor problem, replace it while there is no developer in the unit. Clean all toner residue from the PCU.
        • copier tech
          • 8192
          #19
          If this was my call i'd order a new dev unit, bag of developer, update all the firmware then fit the parts & not forgetting to run the dev setup procdure (SP2-801-001) I think as only did one myself last week, if you didn't perform this then that might be your problem.
          • PA3040
            • Jun 2014
            • 171
            #20
            Dear slimslob
            Thanks for the reply and advice
            In my case, some machines get effected withing two months after selling ( Brand new machine with original Developer and toner )
            • PA3040
              • Jun 2014
              • 171
              #21
              I did firmware update but what is the reason to replace the development unit the machine still new,
              After replacing the developer the copy quality is perfect
              Ricoh has released a new firmware to solved the problem which dirty background of the backside paper when making SMC print
              But my case normal printing and copying
              • copier tech
                • 8192
                #22
                Just to rule out the dev cylinder & TD sensor, if they're arn't to expensive worth it as a precaution.
                Have you looked into what the customer is printing? Long runs with very little print on the page or long runs with a lot of txt & photos etc can cause this kind of issue.
                • PA3040
                  • Jun 2014
                  • 171
                  #23
                  [QUOTE=copier tech;423761]
                  Impossible because after replacing developer one customer make 6500 copies
                  Let say, you are correct, but we didn't notice this type of problems with MP2000 series machines since one of my customer is using both machine in the copy shop
                  I will try this
                  • copier tech
                    • 8192
                    #24
                    Yes but an MP2000 is not the same as an MP2001 hence the different Dev part numbers!
                    • PA3040
                      • Jun 2014
                      • 171
                      #25
                      You are telling problem with developer?
                      • copier tech
                        • 8192
                        #26
                        No! All i'm saying (as was said above) the 2000 & 2001 dev is not the same
                        • PA3040
                          • Jun 2014
                          • 171
                          #27
                          Yes, That is obvious
                          • Waliul
                            • Jul 2010
                            • 20
                            #28
                            Please try to use OEM Developer (D1589640) & OEM Toner (EDP CODE: 842009/Europe Version)
                            for the above machine. I hope problem will be solve.
                            Thanks.
                            • PA3040
                              • Jun 2014
                              • 171
                              #29
                              Thanks.
                              Dear Waliul,\ Thanks for the reply
                              We ordered only Ricoh genuine ( OEM) toners and developers from ricoh. Toner EDB code is 842012
                              Our continuous observation found that customers are complained after replacing the new toner, some time first toner. Then we checked with the toner and there are no issues since the machine installation had been done by the same toner lot
                              In this situation what our tech's are doing is
                              1. make 10 black copies until toner mark is papered
                              2.then checked the vsg and vsp , Normally vsg 3.92 - 4.01 and vsp above the 1.5(in correct ) ( after black copies done)
                              3.Changed the SP2301 [Tr Current Adj] 004 Cleaning/Negative for background correction
                              4.Changed the SP2929[Vtref Limits] Upper Limit and Lower Limit
                              5.Re initialize the developer
                              in error case we observed that the vsp is not normal and it always above the 1.5
                              Can any one advice how to reduce vsp to correct valve ( vsp<0.5) for new drum
                              What is the meaning of PWM and vsdp
                              Thanks in advance
                                • 37556
                                #30
                                vsp and vsdp are readings taken by the p sensor (ID sensor) immediately following the ID patch. vsdp is used for design purposes only. PWM is calculated during developer initialization and process control. It has to do with the voltage/current applied to the emitter of the p sensor in order to get a valid reading for the surface of the drum prior to the ID patch.
                                That all said, clean the p sensor. It is located in the PTR unit directly below the transfer roller. The sensor gets dirty and process control raises PWM. When PWM is increased, the ID patch looks lighter and process control increases the toner density causing back ground.
