issue
  • vargue
    • Oct 2011
    • 404
    [Dead] issue
    hi fellas i have headache in aficio3045 touch screen shifting so i replaced touch screen glass and all panel but no avail. i swapped interface from infected machine to another. problem do the same issue to another machine. now firmware need to update but yesterday i bought sd card 256MB but it's need to format which way to format this . need advise please help and fat or fat32 or ntfs thanks
  • Tonerbomb
    AutoMajical Resolutionist
    • Feb 2005
    • 2589
    Re: issue
    Use this app to format for Ricoh machines, fat format: SD/SDHC/SDXC Memory Card Formatting Software | Download | SD Memory Card | Digital AV | Consumer Products | Support | Panasonic Global
    Mystic Crystal Revelations
    • Iowatech
      Not a service manager
      • 3930
      Re: issue
      This might be stupid, but have you tried realigning the touch screen?
      Take this with a grain of salt, as it might not be correct, but I think you have to press the "#" key, then the numbers "1993", then press the red stop key five times to get to the screen that has that option. I've found a plastic tweaker ground to a point helpful when I've had to realign the touch screen, for what it is worth.
      • sandmanmac
        • 3983
        Re: issue
        It's true Iowatech.
        Vargue has made no mention of performing the calibration, which is a must after replacement, and I've not heard of firmware ever being the cause of this particular problem. (correct me if I'm wrong)
        As for the procedure to access the adjustment, you're VERY close, but it's Clear modes, 1,9,9,3, clear/stop (5 times).
          • 37556
          Re: issue
          I just checked the SM. Yellow - 1993 - Orange 5 times.
          • vargue
            • Oct 2011
            • 404
            Re: issue
            hi guy's first thing i made this pullshit 1993 and no avail that's what happend. i spend half hour in this pull shit program .i have customer have another 3045 .and touch screen working good. first i mentioned that i replaced touch screen glass but nothing. then made 1993 and 5 red cancel but shifiting is so far .i touched first tray .touch screen go to text/photo.then swapped interface in two machines until now problem existed in another machine. my finger hurt me untill now lol .
            • Iowatech
              • 3930
              Re: issue
              About the SD card, format it in FAT format.
              Also, don't use Windows XP or earlier Microsoft based machines, there was a program that needed to be downloaded for formatting SD cards for Ricoh firmware updates on those computers. I'd tell you what it was, but the computer that contained that information died last year, and I haven't used the program in years. And hopefully you are using something newer.
              (Actually, if possible, harvest the SD cards from Ricoh machines that are going to be scrapped or broken down for parts. Those SD cards have always worked for firmware updates for me.)
