Any solution to Reset NV Ram Meter Reading to "0"
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: Any solution to Reset NV Ram Meter Reading to "0"
    Originally posted by Wind Cool
    Actually for MPC3300 only this case, is request from my customer. Because they been use for 1 year already. They want to reset every year for easy them to calculate also....
    Your argument doesn't merit or carry weight on this.reset the pm counters or set up user codes and reset them. Don't need to reset the total counters the reason is for one reason to hide the true history of the machines life.
    Incontinentia Buttocks
    • Wind Cool
      • May 2014
      • 82
      Originally posted by Oze
      Take your 49 posts and F***K OFF.
      You reply with a good message .... i'm proud of you
      • Copier Doc
        • Mar 2010
        • 49
        Wind Cool? Sounds more like hot air! As Oze said f@@k off, this aint the place for you!
        • kannuki2
          • Feb 2012
          • 398
          #19
          There are numerous solutions to track the meter usage on the copier. For instance, you can use SmartDeviceMonitor: Printer Management Software to monitor all print, copy, scan and fax activity for Ricoh devices. Or simply use "user codes authentication" feature that is already come with all the Ricoh copier for tracking meter usage. Why do you bother to reset the meter reading?
          • slybot
            • Sep 2010
            • 165
            #20
            Said customer can't take reading at beginning of the year and then again at the end of the year and subtract smaller number from the bigger number to get the meter count?? sounds like a lesson in mathematics is in order
            • Oze
              Ricoh Fanboy
              • 1663
              #21
              He can spout as many bullshit reasons to try and justify resetting meters all he likes but a): IT's illegal and b):IT'S ILLEGAL
              • QCS
                • Jul 2023
                • 2
                #22
                RICOH METER RESET
                – Canon Meter Reset
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  #23
                  • Gift
                    • Mar 2011
                    • 2459
                    #24
                    So you are not interested in buying overpriced NV Rams then?
                      • 37491
                      #25
                      I'm not interested in anything from a new member that has all the indicators of being a spam bot.
                      • QCS
                        • Jul 2023
                        • 2
                        #26
                          • 37491
                          #27
                          Let's see, first post on the day you joined and you posted a link to a website. That is SPAM. And you had to dig up a 9 year old post that had been dead and buried to so. That is grave robbing.
                          If you want to advertise, buy advertising.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            #28
                            Too bad copiers and MFPs don't have resettable trip odometers, like a car.
                            But the truth is that they don't (at least that I've ever seen, anyway).
                            • tsbservice
                              Field tech
                              • 8016
                              #29
                              From your profile seems like you are experienced professional but from how long you mister Rose keep this secrets?
                              What do you expect from people following your links? Meter resetting in UK after Brexit legal?
                              • Gift
                                • Mar 2011
                                • 2459
                                #30
                                It speaks! ChatGPT works wonders
                                Next day you'll see a black van in your driveway LOL
