MP C3500/4500 Toner Pump
  • sandmanmac
    • 3981
    Just visited a customer that had the "add toner" message. The bottle still had some toner in it, so I just went right to replacing the pump, but the message didn't clear.
    Then I got around to checking the output, and it doesn't 'click' like the other 3 when activated - with either the new or old pump.
    It was a used pump that I grabbed out of parts machine I have, so I assumed it must be just another bad one, but when I got it back to my shop and re-installed it, it clicks and works properly.
    This problem has ALWAYS been a pump or hose issue for me, but I see that it can be caused by a firmware issue, and/or maybe an engine clear might help. I don't know what firmware level is currently installed, but I'll take an SD card with the 'freshest' stuff with me tomorrow.
    What I'm wondering is, if that was actually the problem, would the machine actually be locked up so that it wouldn't even respond to the output check?
    Anyone have any other suggestions /experiences to arm me with before I get back there tomorrow?
    Thanks!
    EDIT: I just found a configuration page from some time ago, and the system firmware is at least Version 1.69, so that wouldn't seem to be the problem. Am I looking at an IOB perhaps?
    • 23009
    Re: MP C3500/4500 Toner Pump
    Do these toner pumps employ an electromagnetic clutch? I seem to recall seeing that variety somewhere. Maybe the clutch is malfunctioning, or that clutch isn't getting the ground signal? =^..^=
    • sandmanmac
      • 3981
      Yes, that's the "click" you would normally hear on the output check
      • Iowatech
        Not a service manager
        • 3930
        Just my two cents, but if the machine was locked up enough that it was preventing that toner pump from engaging in output mode I'd think the other pumps most likely wouldn't engage as well then either.
        Anyway, as the pump didn't activate in the output test mode or in normal machine operation, conditions that are different, the inputs that activate pump drive apparently don't matter and you are probably right about the IOB board. Although it wouldn't hurt to double check the wiring to the pump first. A loose connector or a broken wire have caused me unexpected problems a time or two.
          • 37532
          Yes. The clutch is actually part of the pump. That's the two lead connector on the pump. There might be a loose connection going to the pump, broken or pinched lead in the harness or a bad output device on the board.
          • sandmanmac
            • 3981
            That's kind of what I was thinking too
            I did pull the connector out of the frame, and checked the pins and re-seated both ends. I'll have a closer look at the harness tomorrow, and take an IOB with me. That seems to be where this is leading
            I appreciate the input guys.
            • Boogi11
              • sandmanmac
                • 3981
                Well Fellas...the problem is resolved.
                In an attempt to not embarrass myself any further, I will just say that it was a defective toner pump all along (&*$!@#!!!!) , and a simple series of foolish errors on my part sure resulted in a couple of days of unnecessary headaches!
                But, at least I don't have to stew over it for the whole weekend!
                Maybe I'll treat myself to an old-fashioned style headache - by having a couple too many beers!
                Don't be too hard on me
                  • 23009
                  Congratulations. I guess I've been pretty fortunate. All my toner pump issues were resolved by cleaning the tubing.
                  • Iowatech
                    • 3930
                    Glad the problem got fixed. Don't worry about the confusion, that happens to the best of us, and also me.
                    • Tonerbomb
                      AutoMajical Resolutionist
                      • Feb 2005
                      • 2589
                      Been there, Done that.......................
                      Mystic Crystal Revelations
                      • mikadonovan
                        • May 2008
                        • 2931
                        I hate when that happens Guess you're human just like the rest of us.
                        NEVER ASSUME ANYTHING
                        • iliketui
                          • May 2014
                          • 48
                          I am having similar issues with an MPC 4500.
                          I have replaced the black PCDU, toner pump, hose and tried using 3 different toner bottles (2 known new ones).
                          If i open and close the front door the machine says loading toner, then the message goes away and am able to print about 4 pages before the load toner message comes back.
                          Each time i replace the toner bottle the on screen toner indicator bar only shows one bar.
                          The only thing left I can think of is to replace toner nozzle assembly.
                          Any ideas would be greatly appreciated.
                            • 37532
                            In the future, start a new thread.
                            That said, the problem might have something to do with the RFID board on the machine. The RFID reads from and writes to the chip on toner bottle the toner remaining percentage.
                            • andrewdecruz
                              • Jul 2009
                              • 74
                              @sandmanmac.....hahahaha...good on you mate.
                              Btw, you haven't been gorging your eyes out watching too much world cup football have you?
                              Neway, keep up with the posts...always great to have you on board...
                              Cheers
