Ricoh MP 2551 SC 553 Error code
  • Doug James
    • Jan 2012
    • 935
    #31
    Re: Ricoh MP 2551 SC 553 Error code
    Originally posted by Lagonda
    Oh dear, oh dear, it looks like some people need to sit on the naughty chair for awhile, if you can't play nicely together........
    Now to get back to your original problem, are you sure every thing is plugged into the PSU? I would suspect that the triacs are turning the lamps on but there is no feed back to the temp control circuit.
    I just got the copier running. You suspected right. The control wire for the temp control circut was (kinda) buried in a wire harness and the male connection was in the upper right hand corner of the board. Thanks so much for your feedback again !!!
      • 37553
      #32
      And thank you for letting us know what the problem was and that it is corrected.
      • Lagonda
        • Aug 2008
        • 1649
        #33
        Happy to help
        And happy to do it without a lot of personal invective. I hope that B Bishop had an early night and got out of the right side of the bed today
        • Doug James
          • Jan 2012
          • 935
          #34
          Happy to help
          Same here...
