Ricoh MP 2551 SC 553 Error code
  • sandmanmac
    • 3983
    #16
    Re: Ricoh MP 2551 SC 553 Error code
    Originally posted by banginbishop
    Good luck with fixing your attitude and the problem machine but your attitude wilfor yourl take more work!
    I can see how you may have mistaken Doug's response for sarcasm Bishop, but i think it was meant as a sincere 'thank you' for the input- we may never know, but that's certainly how i read it.
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      #17
      cheers sandmanmac but the word GREAT in caps said it all. ive had countless thermistors play up, visual inspection revealed nothing but checking the temp display showed them going up and down like a whores draws in 10-20c when it should have been stable or showing 0 degrees. Ive been caught out many times by resetting the codes printing copies off and getting a recall because the thermistors are knackered. Too many engineers just throw parts at a machine and not fault finding.
      I offer up a resonable simple check and I get a half wit trying to be cocky with me. sorry but ive done too many ricoh, canon, kyocera sharp courses to be talked down to by somone who thinks its big and cleaver when he clearly cant tell his arse from his elbow!
      Incontinentia Buttocks
      • Doug James
        • Jan 2012
        • 935
        #18
        I use this forum to get "unstuck" I works on all machines and only certified of Canon and Xerox. My brain gets caught up "in the trees" so much I sincerely welcome the input. Someone will say something like check the fuser temp and I go duh... I always have found it amusing that every tech that I have ever met thinks he or she is always smarter than the any other tech around them. Their wisdom is much more intense than anyone. The truth is though, the job we do is 70% customer relations. 30% ability to fix the machines (in my opinion). Their is no reason to make judgement calls on any techs ability or get angry. We really have a tough job and everyone has their own style. Neither good or bad unless we succed on pissing off all of our customers. Then we need to find another line of work....
        • banginbishop
          grumpy old git
          • Oct 2007
          • 894
          #19
          So have you checked the temp then? What was the readings? Have you ran a meter on them? Have you NEVER missed something so simple because you forgot to do the simple things? I have and every engineer I know has! You come on here asking for help , i posted that because a lot of engineers don't do the basic checks and start looking to deep. It had nothing to do with questioning your abilities as an engineer but when you insult me with the way you did,yes I'll get pissed off!
          • Doug James
            • Jan 2012
            • 935
            #20
            No I haven't checked that. I am going to do that first thing when I get back to the customer... I actually feel a little stupid for not thinking of that.... I sure do apologize that my comment sounded like i didn't appreciate your feeback. You are actually saving my ass. See... I first saw the machine with no power... Fixed that problem and am starting to see that problem also existed. One of those type of deals....
            • banginbishop
              grumpy old git
              • Oct 2007
              • 894
              #21
              Lets move on had a shit day with my bank and no need to fall out with engineers have enough crap from customers. Let us know how you get on.
              • slybot
                • Sep 2010
                • 165
                #22
                hey, im not the sub standard engineer who cant figure out or do basic troubleshooting! try reading the manual mr "i know it all but know fook all"
                been doing this job for 20 plus years and i know that i start by checking the temp readings easily by sp 1106 before i even take the machine apart.
                Good luck with fixing your attitude and the problem machine but your attitude will take more work!
                sorry, i have also been doing this job for 20 plus years and i find your reply totally disgustingly arrogant. have you never had a brain fart?.... if the thermistors are acting dodgy then what are the readings out of the SP modes going to clarify................... this is where logic comes into play and you don't need to look at an SP mode...................or maybe i am just a lower form of tech than you.
                • slybot
                  • Sep 2010
                  • 165
                  #23
                  we all have shit days with our banks bnb. no need to take it out on fellow techs.
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    #24
                    well thanks for your input on this. well if you cant understand that sp1106 gives you a reading of the tempreture at its current state then YES IM A COCKY MUTHER F***ER. ive seen machines at ready stage but checking this sometimes reveals the temp reading droping 10-20 degrees within half a second or it can show 0 degrees - hence giving me an indication that the thermistors may be at fault before i start to swap boards out. If you check sp1106 there are sometimes 3-4 reading like end, middle or press thermistors. So yes it can help. Maybe thats just me being disgustingly arrogant but id rather do a basic check like this.
                    I recommend you read ALL of the posts before starting to comment and yes you've just made yourself look an idiot by bringing this up when it was done and dusted were we both sorted it out.
                    again well done on your informative post. Must go I have a life to live and cant be arsed when this as it was sorted out with the OP.
                    • slybot
                      • Sep 2010
                      • 165
                      #25
                      ok now you have annoyed me. i read all of the posts 2 and 3 time over before i posted it. maybe you didnt understand where i was going on this..........yet again i will say if the thermistor that you are reading through the SP mode is giving a false reading then you have to rely on common sense...... so by saying i am a dimwit by saying i haven't read your post????????
                      • slybot
                        • Sep 2010
                        • 165
                        #26
                        sorry yet again. are you a xerox tech/ex xerox tech
                          • 37553
                          #27
                          I find SP 1106 quite useful. After resetting the fusing code, I will turn the machine on with the door open. Once I am in SP 1106 and monitoring the various temperatures, I close the door. If one reads zero, it usually means a bad thermistor, normal cold reading in my climate is in the mid 20's. If one stay at the same reading in the first 5 seconds, I open the door again. No point in popping another code, especially on the color machines that require replacing a fuse on the fusing unit in order to clear the code.
                          • Doug James
                            • Jan 2012
                            • 935
                            #28
                            Thanks so much
                            • Lagonda
                              • Aug 2008
                              • 1649
                              #29
                              Oh dear, oh dear, it looks like some people need to sit on the naughty chair for awhile, if you can't play nicely together........
                              Now to get back to your original problem, are you sure every thing is plugged into the PSU? I would suspect that the triacs are turning the lamps on but there is no feed back to the temp control circuit.
                              • Doug James
                                • Jan 2012
                                • 935
                                #30
                                I've double and triple checked... I have some thermistors coming tomorrow. I will know then and post it....
