MPC3003 Inport/Export setting to USB drive
  • copier tech
    • 8169
    [Misc] MPC3003 Inport/Export setting to USB drive
    Hi all,
    I'm swapping an mpc3003 for a faster mpc4503 & want to export all the settings, ip, smtp, address book etc to the new mpc4503, is it possible to do this via a usb stick drive, eg can I export the 3003 setting to USB drive then import them to the 4503?
    I am aware I can do it via the WIM, but doing at the MFP via USB would be easier for me at this particular location.
    Thanks.
  • tankmurdock
    • Apr 2014
    • 13
    Re: MPC3003 Inport/Export setting to USB drive
    I am pretty sure the only way to import or transfer information besides through the WIM is with an SD Card. You can import all the copiers settings onto a blank SD card then insert it into the new one and import. Add'y Book, NIC, SMTP, NVRam etc.
    I don't think any service information can be obtained via a USB drive as of yet.
    Hope that is helpful
    • copier tech
      • 8169
      Yes thats a great help, is the procedure under system tools?
      • tankmurdock
        • Apr 2014
        • 13
        No sir, it's all in the service mode of the copier...under the 5XXX-XXX section.
        • ruben
          The New Guy
          • Oct 2012
          • 1203
          Settings: SP5-749-001 to export (to SD?) and -101 to import, I believe, the SP modes are a bit vague.
          Address Book: SP5-846-051 to export to SD and -052 to import.
          • Moza
            • 232
            I think 03 models have the option to export device settings to usb in admin tools
            • fbkhan3
              • May 2012
              • 421
              Import.JPGImport 2.JPG yes it's possible to do but address book is exceptional, it's old traditional way through Sp for (address book backup). other settings can be import/export and managed with a SD card. in front slot in Operation Panel. make sure you have Admin Authentication ''ON'' to find the Import/export Option in system setting. Hope it helps
              • copier tech
                • 8169
                Thanks for the info here, I was able to back up & restore the address book to SD card in service mode no problem.
                I also exported the machine settings to SD OK by using SP5-749-001 to export but when I tried to import using SP5-749-101 on the new machine it just said failed, any idea why?
                It wasn't a big issue as I printed on the network settings etc on the old machine.
