how to disable TIFF altogether and leave only PDF for scan to folder 6000 or 65000
Ricoh 6000 6500 disable TIFF-please HELP!
Re: Ricoh 6000 6500 disable TIFF-please HELP!
Also refer to Ruben's prompt reply to your other request for the same thing:
http://www.copytechnet.com/forums/ri...er-issues.html -
gaprinda
I have read a lot all manuals.
You are wrong thinking I am posting something which is in manual
on other thread you put a gif which I know by heart
Question is nor about "DEFAULT FILE TYPE"
Question is to get rid of TIFF as an option altogether
This is a request from company owner, If I tell him this is impossible by design I need to make sure I am no lying
So please tell me (you must be knowledgeable) is this technically possible to hide , remove disable get rid of TIFF option altogether
Many thanks
This is 'user manual' stuff. Read it!
http://www.copytechnet.com/forums/ri...er-issues.htmlComment
Many thanksComment
Once its set as default there should be no need for the user to go in and change it.
As far as the RTFM comments my usual response is GFYS... if I have already read the manual. ;-)
My reply to someone asking a question that's in the manual is to give them the page number and name of the manual its in.Comment
Set pdf in scanner mode and hit program button and program as defaultComment
