Ricoh 6000 6500 disable TIFF-please HELP!
  • gaprinda
    [Misc] Ricoh 6000 6500 disable TIFF-please HELP!
    how to disable TIFF altogether and leave only PDF for scan to folder 6000 or 65000
  • sandmanmac
    • 3981
    Re: Ricoh 6000 6500 disable TIFF-please HELP!
    This is 'user manual' stuff. Read it!
    Also refer to Ruben's prompt reply to your other request for the same thing:
    http://www.copytechnet.com/forums/ri...er-issues.html
    • gaprinda
      I have read a lot all manuals.
      You are wrong thinking I am posting something which is in manual
      on other thread you put a gif which I know by heart
      Question is nor about "DEFAULT FILE TYPE"
      Question is to get rid of TIFF as an option altogether
      This is a request from company owner, If I tell him this is impossible by design I need to make sure I am no lying
      So please tell me (you must be knowledgeable) is this technically possible to hide , remove disable get rid of TIFF option altogether
      Many thanks
        • 37502
        Many thanks
        See my reply in your other request for the same thing.
        • drwevil
          • Nov 2013
          • 53
          As far as Im aware ...no
          Once its set as default there should be no need for the user to go in and change it.
          As far as the RTFM comments my usual response is GFYS... if I have already read the manual. ;-)
          My reply to someone asking a question that's in the manual is to give them the page number and name of the manual its in.
          • redneckstylin
            • Sep 2011
            • 173
            Set pdf in scanner mode and hit program button and program as default
            • drwevil
              • Nov 2013
              • 53
              pretty sure he knows how to set the default...
              He is wanting to remove the TIFF option altogether as far as I'm aware its not possible... why would you anyway?
